coq-club - Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?
  • Date: Tue, 08 Oct 2013 09:52:53 +0200
Le 07/10/2013 17:33, Pierre Boutillier a écrit :
Hi
Yes
On 07/10/2013 16:57, Frédéric Blanqui wrote:
Generalized Iteration and Coiteration for Higher-Order Nested Datatypes
<http://www2.tcs.ifi.lmu.de/%7Eabel/fossacs03.pdf> Andreas Abel, Ralph
Matthes and Tarmo Uustalu.
/Foundations of Software Science and Computation Structures (FoSSaCS
2003)/, LNCS 2620
<http://www.springer.de/cgi/svcat/search_book.pl?isbn=3-540-00897-7>
tells us that Michiel's example should be accepted.
Yes (as far as I understand) the restriction on reccursive arguments are
made because polymorphic types can postpone negative type occurence that
must be rejected as you explain here :
Hello.
Thanks Pierre for your example but I do not really understand how it is
related to Michiel's problem.
In your example, the problem does not seem to be related to polymorphism
only. Here, the polymorphism hides a negative type, namely
(instantiating P by I):
Inductive I : Type := C: (I (*negative occurrence of I*) -> I) -> I.
(*rejected by Coq*)
And, elimination on negative types is not normalizing [Mendler 86]. You
proposed:
Fixpoint f i : A (*anything*) := match i with C x => f (x i) end.
Then, taking i := C (fun i => i), you get: f i ->iota f ((fun i => i) i)
->beta f i.
More generally, with:
Inductive I : Type := C: (I -> A (*anything*)) -> I. (*rejected by Coq*)
Fixpoint p i := match i with C x => x end.
and d := fun x => p x x, you get: d (C d) ->beta p (C d) (C d) ->iota d
(C d).
I don't undestand your point in
Also, it is not clear to me why "polymorphic arguments of a constructors
must not be [admissible subterms]." Otherwise, we could not have records
with type fields in Coq. Take for instance:
Inductive I (*: Type*) := C : forall A (*: Type*), B A (*anything*) -> I.
Fixpoint p1 i := match i with C A _ => A end.
Fixpoint p2 i := match i as i return p1 i with C _ b => b end.
p1 and p2 are accepted, they are not really fixpoints by the way, they
do not do recursive calls !
Do you want to say that a term of skeleton "fix f (x : I) := E (f (p2
x))" (with E a close term) should be accepted ?
Hello Pierre.
My point was, rather as a remark, that you do not need to define a recursive function to get non-termination. Simple, apparently innocuous projections like p above or below, may be enough, if your inductive type does not satisfy some conditions.
Best regards,
Frédéric.
These 2 points are really interresting :
On the other hand, the definitions of p1 and p2 are rejected by Coq if I
is declared of sort Prop and A of sort Type. Indeed, in this case, the
calculus is not normalizing and not consistent [Coquand, LICS'86].
Finally, note that positivity ensures termination and consistency when
constructor arguments are at the object level [Mendler] but not always
when they are at the type level [Coquand-Paulin, COLOG'88]:
Inductive I : Prop := C : ((I->Prop)->Prop)->I.
Allowing Fixpoint p i := match i with C x => x end, turns C into an
injection from (I->Prop)->Prop to I, but there cannot be any injection
from (A->Prop)->Prop to A, nor from A->Prop to A, whatever A is.
Best regards,
Frédéric.
Pierre B.
