- To: Hendrik Tews <tews AT os.inf.tu-dresden.de>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] dependency graph (again)
- Date: Thu, 10 Oct 2013 13:03:23 -0400
I might be interested in such a tool to replace the regex parsing I do on lines 11, 36-39, and 51 of https://github.com/JasonGross/coq-bug-finder/blob/master/replace_imports.py. (Or at least in looking at the source code of it to make my regex more robust.) (The purpose of this script is to take a target .v file which lives in the context of a larger development, and transform it into a functionally equivalent .v file which is stand-alone, by inlining the imports.)
-Jason
coq-club AT sympa.inria.fr writes:
If you only want to get a dependency graph of your modules, there is a
set of patched files letting you tell coqdep to dump a .dot file on the
coqtail repository (they may be out of sync with coq's source code
though...): http://sourceforge.net/p/coqtail/code/HEAD/tree/depend/
For the dependency graph of the source files, I use a simple
program that parses the coqdep output and generates dot files.
Slide 22 (ie, the second last) of [1] has been generated with it
(though I added the colors by hand). If there is interest, I can
make this little tool public.
Bye,
Hendrik
[1] http://www.askra.de/slides/cut-eli-slides.pdf
- Re: [Coq-Club] dependency graph (again), coq-club, 10/02/2013
- Re: [Coq-Club] dependency graph (again), Hendrik Tews, 10/07/2013
- Re: [Coq-Club] dependency graph (again), Jason Gross, 10/10/2013
- Re: [Coq-Club] dependency graph (again), Kristopher Micinski, 10/10/2013
- [Coq-Club] coqgraph - visualize file dependencies for Coq projects [was: dependency graph (again)], Hendrik Tews, 10/11/2013
