- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Using modules as namespaces
- Date: Thu, 10 Oct 2013 13:20:17 -0400
Hi,
I would like to use [Module]s as namespaces, in particular allowing qualified access to constants.
For example, I would like to be able to define some things in a module [A], and then do something in a module [B] so that anything I can access as [A.foo] can now be accessed as [B.foo]. The following demonstrates what I would like to do, and that it does not work:
$ cat A.v
Axiom x : Type.
$ cat B.v
Require Export A.
$ cat C.v
Require B.
Check B.x.
$ coqc A B
$ coqc C
File "./C.v", line 2, characters 6-9:
Error: The reference B.x was not found in the current environment.
The reason I want to do this is that I need to split apart definitions into various files (both for dependency reasons, and to increase parallelizability of `make`, and because it's nicer not to put everything into a few monolithic files), but I want to be able to refer to [sum] in "Category/Sum.v" as [Category.sum], not [Category.Sum.sum]. (It seems to me that Coq's namespace facilities are crippled if I can do neither this nor have mix-in namespaces, where I define some constants in one place and other constants in another file, and have them both join the same namespace.)
-Jason
- [Coq-Club] Using modules as namespaces, Jason Gross, 10/10/2013
- Re: [Coq-Club] Using modules as namespaces, Geoff Reedy, 10/10/2013
- Re: [Coq-Club] Using modules as namespaces, Jason Gross, 10/10/2013
