- To: Valentin Robert <valentin.robert.42 AT gmail.com>
- Cc: Adam Chlipala <adamc AT csail.mit.edu>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] eq_rect
- Date: Tue, 15 Oct 2013 12:47:15 -0700
I've written the following example. Assertion 4 seems to imply that the type of E need not be fixed.
Can someone verify that the assertions / reasoning are correct? (All I know is that Coq accepts the definition, not whether Coq accepts the definition for the reason I think it accepts it).Inductive Cat : Type := cat. Inductive Dog : Type := dog. (* Assertion 1: This fails because Coq can't infer this. *) (* Definition weird (b: bool) := match b | true => cat | false => dog end. *) (* Assertion 2: this works because if we provide the type, it's a valid type *) Definition weird (b: bool) := match b as y in bool return (if y then Cat else Dog) with | true => cat | false => dog end. (* Assertion 3: this can not work since (weird b) has type (if b then Cat else Dog), which does not fall into (T x1 x2 ... xn) *) (* Definition can_not_work (b: bool) := match (weird b) as ... in ... return ... with ... end. This can not possibly work since (weird b) has type (if b then Cat else Dog), which doesn't fall into T x1 x2 ... xn *) Inductive iList : nat -> Set := | INil : iList O | ICons : forall n, nat -> iList n -> iList (S n). Fixpoint sum {n: nat} (lst: iList n) := match lst with | INil => 0 | ICons n x xs => x + (sum xs) end. Require Import ZArith. (* Assertion 4: the type of lst doesn't have to be fixed Our return type can be function of both the _value_ AND _type_ of the discremee *) Definition black_magic (n: nat) (lst: iList n) := match lst as y in iList n return if (NPeano.odd (n + sum lst)) then Cat else Dog with | _ => match (NPeano.odd (n + sum lst)) as y in bool return if y then Cat else Dog with | true => cat | false => dog end end.
On Tue, Oct 15, 2013 at 10:36 AM, Valentin Robert <valentin.robert.42 AT gmail.com> wrote:
1) The type of E is fixed, I just needed names to refer to the
concrete instances of the indices in E. So e1 stands for whatever
concrete value the term E has for its first index.
2) It's actually put quite well in Adam's book.
- Valentin
On Mon, Oct 14, 2013 at 9:10 PM, t x <txrev319 AT gmail.com> wrote:
> 1) I was not aware that the _TYPE_ of E could also be different. Previously
> I thought that the type of E was fixed, but the "match type" can depend on
> the value of E. Now, it's clear to that even the type of E is not fixed.
> 2) I'm still not convinced I understand dependent type matching (though
> Adam's 4 paragraphs in CPDT is starting to make more sense.)
> Is it possible to express "the one rule of dependent type matching" as a
> inference rule, i.e. things like:
> Env |- t1: A -> B
> Env |- t2: A
> Env |- t1 t2 : B
> On Mon, Oct 14, 2013 at 3:38 PM, Valentin Robert
>> Rather (assuming we only talk about indices), if:
>> E : T e1 ... en
>> and:
>> T :=
>> | Ci: ... -> T ci_1 ... ci_n
>> Then it is checked that:
>> 1) Bi : U {y is replaced by Ci, xk is replaced by ci_k}
>> And the resulting term has type:
>> 2) FinalType = U {y is replaced by E, xk is replaced by ek}
>> Unless I'm mistaken.
>> - Valentin
>> On Mon, Oct 14, 2013 at 3:11 PM, t x <txrev319 AT gmail.com> wrote:
>> > Valentin: this is helpful, but I'm not quite there yet.
>> > Adam: I've seen that section of
>> > http://adam.chlipala.net/cpdt/html/MoreDep.html before -- unfortunately,
>> > I
>> > find the prose difficult to understand.
>> > Can I think of type checking as follows:
>> > Suppose have:
>> > match E as y in (T x1 ... xn) return U with
>> > | C1 z1_1 z1_2 ... z1_m1 => B1
>> > | C2 z2_1 z2_2 ... z2_m2 => B2
>> > | Ci zi_1 zi_2 ... zi_mi => Bi
>> > end : FinalType
>> > then to have a valid type check, we need the following properties:
>> > 1) forall i, (E = Ci zi_1 ... zi_mi) ->
>> > type_of ( Bi ) = U { y replaced with Ci zi_1 ... zi_mi}
>> > 2) there needs to be some relation between U and FinalType -- but I
>> > think
>> > it's more subtle than "U = FinalType"
>> > On Mon, Oct 14, 2013 at 2:52 PM, Adam Chlipala <adamc AT csail.mit.edu>
>> > wrote:
>> >> Section 8.2, "The One Rule of Dependent Pattern Matching in Coq," in
>> >> CPDT
>> >> <http://adam.chlipala.net/cpdt/> might clear this up. There really is
>> >> a
>> >> pretty straightforward typing rule behind this behavior and that of all
>> >> [match]es in Coq.
>> >> On 10/14/2013 05:35 PM, t x wrote:
>> >>> 1) eq_rect =
>> >>> 2) fun (A: Type) (x: A) (P: A -> Type) (f: P x) (y: A) (e : @eq A x
>> >>> y)
>> >>> 3) match e in (@eq _ _ y0) return (P y0) with
>> >>> 4) | eq_refl => f
>> >>> 5) end :
>> >>> 6) forall (A: Type) (x: A) (P: A -> Type),
>> >>> 7) P x -> forall y : A, @eq A x y -> P y
>> >>> 8) Inductive eq (A: Type) (x: A) : A -> Prop := refl-equal : eq A x x.
>> >>> I'm reading Chapter 8 of Coq d'Art, and trying to better understand
>> >>> eq.
>> >>> "equality" has been interesting in that (1) there were many "obviously
>> >>> equal" things that Coq did not agree with me on and (2) I still don't
>> >>> understand how Coq's equality works.
>> >>> The above definition -- especially line 3, seems a bit magical to me:
>> >>> a) we say "match e in (@eq _ _ y0)" -- so y0 must be bound to y
>> >>> b) then we say "return (P y0)", which means "return (P y)"
>> >>> c) but then we return f, which has type "(P x)"
>> >>> and Coq is happy and fine with this. I'm not happy with this. What is
>> >>> Coq
>> >>> doing to convert the "(P x)" to a "(P y)" and why is it allowed in
>> >>> this
>> >>> case?
- [Coq-Club] eq_rect, t x, 10/14/2013
- Re: [Coq-Club] eq_rect, Valentin Robert, 10/14/2013
- Re: [Coq-Club] eq_rect, Adam Chlipala, 10/14/2013
- Re: [Coq-Club] eq_rect, t x, 10/15/2013
- Re: [Coq-Club] eq_rect, Valentin Robert, 10/15/2013
- Re: [Coq-Club] eq_rect, Geoff Reedy, 10/15/2013
