- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] eq_rect
- Date: Tue, 15 Oct 2013 17:11:46 -0400
On Tue, Oct 15, 2013 at 12:47:15PM -0700, t x said
> I've written the following example. Assertion 4 seems to imply that the
> type of E need not be fixed.
> (* Assertion 4: the type of lst doesn't have to be fixed
> Our return type can be function of both the
> _value_ AND _type_ of the discremee *)
> Definition black_magic (n: nat) (lst: iList n) :=
> match lst as y in iList n return if (NPeano.odd (n + sum lst)) then Cat
> else Dog with
> | _ => match (NPeano.odd (n + sum lst)) as y in bool return if y then
> Cat else Dog with
> | true => cat
> | false => dog
> end
> end.
It should go with out saying that lst has only one type, namely iList n.
The "in iList n" just creates a name (n) for the index of iList that can
be used in the return annotation. It is maybe less confusing to give a
different name that doesn't shadow the argument to black_magic:
match lst as y in iList m return if (NPeano.odd (m + sum lst)) then Cat
else Dog with
| _ => match (NPeano.odd (n + sum lst)) as y in bool return if y then Cat
else Dog with
| true => cat
| false => dog
end
end.
- [Coq-Club] eq_rect, t x, 10/14/2013
- Re: [Coq-Club] eq_rect, Valentin Robert, 10/14/2013
- Re: [Coq-Club] eq_rect, Adam Chlipala, 10/14/2013
- Re: [Coq-Club] eq_rect, t x, 10/15/2013
- Re: [Coq-Club] eq_rect, Valentin Robert, 10/15/2013
- Re: [Coq-Club] eq_rect, Geoff Reedy, 10/15/2013
