- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] one rule of dependent matching / implementing dependent types
- Date: Wed, 16 Oct 2013 01:08:45 -0700
I've recently been porting http://math.andrej.com/2012/11/08/how-to-implement-dependent-type-theory-i/ to scheme.
Quoting the section on type inference:** [equal ctx e1 e2] determines whether normalized [e1] and [e2] are equal up to renaming
of bound variables. *)
let equal ctx e1 e2 =
let rec equal e1 e2 =
match e1, e2 with
| Var x1, Var x2 -> x1 = x2
| App (e11, e12), App (e21, e22) -> equal e11 e21 && equal e12 e22
| Universe k1, Universe k2 -> k1 = k2
| Pi a1, Pi a2 -> equal_abstraction a1 a2
| Lambda a1, Lambda a2 -> equal_abstraction a1 a2
| (Var _ | App _ | Universe _ | Pi _ | Lambda _), _ -> false
and equal_abstraction (x, t1, e1) (y, t2, e2) =
equal t1 t2 && (equal e1 (subst [(y, Var x)] e2))
in
equal (normalize ctx e1) (normalize ctx e2)
Everything in the above section makes sense. However, it lacks:
match E as y in ... return ... with
end
Thus, my question:
is "the one rule of dependent type matching"
a) a derivation from dependent theory alone?
b) a derivation from inductive types alone?
c) a derivation that only arises from dependent type theory + inductive types?
I believe it's (c), since "a" alone does not provide inductive types / multiple constructors -- thus nothing to match on; and "b" alone ends up being STLC. Now, assuming it's (c), where can I read up on the mathematical foundations of this? [I've looked through chapters in Coq d'Art, but it's not clear if it's defined in the book.]
Thanks!
Thanks!
- [Coq-Club] one rule of dependent matching / implementing dependent types, t x, 10/16/2013
- Re: [Coq-Club] one rule of dependent matching / implementing dependent types, Adam Chlipala, 10/16/2013
- Re: [Coq-Club] one rule of dependent matching / implementing dependent types, t x, 10/16/2013
- Re: [Coq-Club] one rule of dependent matching / implementing dependent types, Rui Baptista, 10/20/2013
