- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: t x <txrev319 AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] one rule of dependent matching (again)
- Date: Tue, 22 Oct 2013 13:52:59 +0200
Sorry for the flood
> Let's omit the fact that there may be PARAMETERS as you do
return clause is not generalized against parameters you just have to change
if expr has type T p_1 .. _p_k u_1 u_2 .. u_n then matchExpr has type
RExpr/{x_1=u_1,x_2=u_2 .. x_n=u_n;y=expr}
if Ci has type forall z_1 .. z_k yi_1 .. yi_mi, T z_1 .. z_k v_1 .. v_n then
Di has type RExpr/{x_1=v_1,x_2=v_2 .. x_n=v_n;y=Ci yi_1 .. yi_mi}
to deal with them.
Pierre B.
- [Coq-Club] one rule of dependent matching (again), t x, 10/22/2013
- Re: [Coq-Club] one rule of dependent matching (again), Pierre Boutillier, 10/22/2013
- Re: [Coq-Club] one rule of dependent matching (again), Adam Chlipala, 10/22/2013
- Re: [Coq-Club] one rule of dependent matching (again), t x, 10/22/2013
- Re: [Coq-Club] one rule of dependent matching (again), t x, 10/23/2013
- Re: [Coq-Club] one rule of dependent matching (again), Adam Chlipala, 10/23/2013
