- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universe Inconsistencies
- Date: Fri, 25 Oct 2013 10:56:43 +0000
- Accept-language: en-US
Dear Matthieu,
Thank you so much. The patch did not work for some reason, but I saw what it
was trying to do, added the line to reduction.ml and now Coq has stopped
complaining. I realise that I am on shaky ground but at least this will allow
me to continue working for the time being.
Cheers, and thanks again.
/Jesper
On 24 Oct 2013, at 16:07, Matthieu Sozeau
wrote:
> Le 24 oct. 2013 à 10:37, Jesper Bengtson
> <jebe AT itu.dk>
> a écrit :
>> Dear Coq club,
> Dear Jesper,
>> In my current development of separation logic I rely heavily on type
>> classes, in a very similar style to work by Spitters et al. I run into
>> similar problems that they did that universe inconsistencies crop up quite
>> regularly. I find these exceptionally difficult to debug. Coq will readily
>> tell me which the offending types are, but to infer the circle (or find
>> out which definitions use these types) the only way that I have found is
>> to print the universes and manually check the levels and for large
>> developments this doesn't really work.
> Indeed, it's a hard issue. There has been improvements already in the trunk
> version, which gives you the cycle in full if you allow printing of
> universes (not in all cases, as [apply] unification hides universe
> inconsistencies for example).
>> I understand that a lot of work has recently gone into fixing this for the
>> HoTT crowd, and I was wondering if any of this is making it into the
>> standard Coq distribution.
> It is planned to be merged with the trunk soon and will be part of the next
> release.
>> For the moment, I would be absolutely fine with an option to just disable
>> the universe checking. To my mind this is analogous to an admit -- it's
>> not something that should be in the end product, but it's perfectly fine
>> to use for development purposes. There was a patch to this effect for Coq
>> 8.3pl3. Is there something similar now?
> Here is a patch for 8.4 if you need it, use at your own risk.
> -- Matthieu
> Index: kernel/reduction.ml
> --- kernel/reduction.ml (révision 16347)
> +++ kernel/reduction.ml (copie de travail)
> @@ -196,6 +196,7 @@
> | CUMUL -> enforce_geq u2 u1 cuniv)
> | (_, _) -> raise NotConvertible
> +let sort_cmp pb s0 s1 cuniv = cuniv
> let conv_sort env s0 s1 = sort_cmp CONV s0 s1 empty_constraint
- [Coq-Club] Universe Inconsistencies, Jesper Bengtson, 10/24/2013
- Re: [Coq-Club] Universe Inconsistencies, Matthieu Sozeau, 10/24/2013
- Re: [Coq-Club] Universe Inconsistencies, Jesper Bengtson, 10/25/2013
