coq-club - Re: [Coq-Club] Induction over ascii
  • To: Marcus Ramos <marcus.ramos AT univasf.edu.br>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Induction over ascii
  • Date: Fri, 25 Oct 2013 00:14:00 +0200
Le Thu, 24 Oct 2013 17:27:33 -0200,
Marcus Ramos
a écrit :
> Hi Auger,
> Thank you for the reply and the hint, now I understand it. Also for
> the suggestion of flipping the bit, but my main concern is indeed the
> proof, not the function itself.
The proof is also easier. There are only two cases to explore (one for
each value of the bit), rather than more than two hundred.
> On the other hand, do you know where I can get an explanation of the
> semantics of "intros [[][][][][][][][]]"?
intros [[][][][][][][][]].
is equivalent to
intros x; case x as [[][][][][][][][]].
For nat, for instance you can do:
intros [|pred].
equivalent to:
intros n; case n as [|pred].
> Neither the Reference
> Manual nor Coq'Art helped me in that. Is there an alternative way of
> splitting all 256 goals?
Flip the bit, so that you will need only 2 goals instead of the 256
you get by using your conversion functions.
> Best Regards,
> Marcus.
