- To: Kristopher Micinski <krismicinski AT gmail.com>
- Cc: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Formalization of SAT solver-related problems?
- Date: Wed, 4 Dec 2013 20:06:27 -0500
On Wed, Dec 4, 2013 at 7:31 PM, Kristopher Micinski <krismicinski AT gmail.com> wrote:
While [proving the correctness of the Tseitin transformation or other propositional logic transformations in Coq] seems interesting as an academic pursuit, I wonder if it's at all practical. Are there any SAT solvers which don't also output certificates?
Most SAT solvers expect CNF input, whereas when modeling a problem you usually want a richer language of propositional logic. A certificate from a SAT solver doesn't help you determine if you've made a mistake in the translation into CNF.
Similar reasoning applies for other simplification passes or translations you might be interested in doing on a rich (i.e., non-CNF) language of propositional logic.
Brad
- [Coq-Club] Formalization of SAT solver-related problems?, Bradford Larsen, 12/04/2013
- Re: [Coq-Club] Formalization of SAT solver-related problems?, Kristopher Micinski, 12/05/2013
- Re: [Coq-Club] Formalization of SAT solver-related problems?, Bradford Larsen, 12/05/2013
- Re: [Coq-Club] Formalization of SAT solver-related problems?, Guillaume Melquiond, 12/05/2013
- Re: [Coq-Club] Formalization of SAT solver-related problems?, Chantal Keller, 12/05/2013
- <Possible follow-up(s)>
- Re: [Coq-Club] Formalization of SAT solver-related problems?, J. Ian Johnson, 12/04/2013
- Re: [Coq-Club] Formalization of SAT solver-related problems?, J. Ian Johnson, 12/05/2013
