- From: Christopher Ernest Sally <christopherernestsally AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors)
- Date: Sat, 7 Dec 2013 08:55:51 +0800
Hi all
Thanks in advance.
Best
Chris
using the tactic "inversion H." on a hypothesis of the form
H : a :: L = b :: L
gives us that a is equal to b. But how can we do the same when we have a function instead of a constructor? Such as in the case of snoc (from Pierce's software foundations, code fragment below).
H : snoc L a = snoc L b
inversion does not work; is there some easy way, possibly through a tactic, to do this? or must one just prove lemmas?
Thanks in advance.
Best
Chris
Inductive natlist : Type := nil : natlist | cons : nat -> natlist -> natlist.
Notation "x :: l" := (cons x l) (at level 60, right associativity).
Notation "[ ]" := nil.
Notation "[ x ; .. ; y ]" := (cons x .. (cons y nil) ..).
Fixpoint snoc (l : natlist) (v : nat) : natlist :=
match l with
| [] => [v]
| h :: t => h :: snoc t v
end.
Fixpoint rev (l:natlist) : natlist :=
match l with
| nil => nil
| h :: t => snoc (rev t) h
end.
Fixpoint app (l1 l2 : natlist) : natlist :=
match l1 with
| nil => l2
| h :: t => h :: (app t l2)
end.
Notation "x ++ y" := (app x y)
(right associativity, at level 60).
Axiom snoc_append : forall (l:natlist) (n:nat),
snoc l n = l ++ [n].
Axiom emp_snoc : forall a L, [] = snoc L a -> False.
Goal forall (l1 l2 : natlist), rev l1 = rev l2 -> l1 = l2.
Proof with auto.
induction l1 as [|n1 l1], l2 as [|n2 l2] ; simpl; intros...
apply emp_snoc in H. contradiction.
symmetry in H.
inversion H. (* no effect *)
repeat rewrite snoc_append in H.
admit.
Qed.
- [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Christopher Ernest Sally, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Abhishek Anand, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Christopher Ernest Sally, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Daniel Schepler, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Julien Forest, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), forest, 12/07/2013
- Re: [Coq-Club] inversion (tactic) on fixpoints (instead of constructors), Christopher Ernest Sally, 12/08/2013
