- To: coq-club AT inria.fr
- Subject: [Coq-Club] How to debug Coq?
- Date: Fri, 6 Dec 2013 04:08:21 +0400
Hello,
I am trying to explore behaviour and fix a patch, so I am using debugger.
So, could anybody provide me with little example about how to set break point in command line for any Coq internal function?
I have read dev/doc/debugging.txt and as it says I use "ocamldebugger-coq" wrapper, but CLI version (not with emacs). Coq is configured with "-local -debug".
I can't set breakpoint on function I want -- separate_extraction from extract_env.ml.
I tried "break separate_extraction" and "break Extract_env.separate_extraction", but these two give me "Unbound identifier <...>".
I have seen text in manual that the function has to be computed and assigned to identifier, so I tried also advance execution to necessary point with "goto <time>".
Command "break @ Extract_env <line>" gives message, that there are no events,
whereas "list Extract_env" succeed.
Sincerely,
Kirill Taran
Kirill Taran
- [Coq-Club] How to debug Coq?, Kirill Taran, 12/06/2013
- Re: [Coq-Club] How to debug Coq?, Hugo Herbelin, 12/07/2013
- Re: [Coq-Club] How to debug Coq?, Kirill Taran, 12/07/2013
- Re: [Coq-Club] How to debug Coq?, Arnaud Spiwack, 12/09/2013
