coq-club - Re: [Coq-Club] How to debug Coq?
  • To: Kirill Taran <kirill.t256 AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to debug Coq?
  • Date: Sat, 7 Dec 2013 10:20:15 +0100
Hi,
> I am trying to explore behaviour and fix a patch, so I am using debugger.
> I have read dev/doc/debugging.txt and as it says I use "ocamldebugger-coq"
> wrapper, but CLI version (not with emacs). Coq is configured with "-local
> -debug".
I don't know how to have the debugger running with CLI. If you
eventually find some, you might create a page on cocorico (e.g. in
section Miscellaneous at
http://coq.inria.fr/cocorico/CoqDevelopment/Public).
At least, the correct name of the wrapper is "ocamldebug-coq" in "dev'.
Also, be sure that all .ml files have been recompiled after you added
"-debug" to the configure script.
Best regards,
Hugo Herbelin
