- To: michael.soegtrop AT intel.com
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to print state of SFLib Case, SCase?
- Date: Thu, 12 Dec 2013 12:34:54 +0100
On 12/12/2013 12:21 PM,
wrote:
Dear Coq Users,
I wonder if it is possible to create a tatctical, which prints the state of
the Software Foundation Case annotation tacitcals in the same way as idtac
"message" prints a message.
As an exerices I tried to do the "advanced expression simplifier" exercise in
SF Imp.v by just repeatedly trying various tacticals. This works astonishingly
well and fast (~1s for ~100 intermediate goals with 13 tactics given to try),
but it is not so easy to understand what tactics are applied to which goal in
which order. I added some idtac "description" but it would be perfect if one
could print the values of all the Case, SCase, ... annotations for each tactic
applied.
And another question: The list of tactics to try starts with reflexivity:
repeat (
try ( reflexivity; idtac "solved" );
but here ; idtac doesn't work, because no new goal is created, so idtac is not
executed. Is there a way to print something after a tactic which solved the
current goal?
One way to go is the following trick
Theorem dup : forall A, A -> True -> A.
intros; assumption.
Qed.
Ltac print_solve t s :=
apply dup; [t; fail | idtac s; trivial].
Goal 1 = 1.
print_solve reflexivity foo.
Thanks & best regards,
Michael
P.S.: I don't want to post the solution of the exercise here so that others
are not robbed of the fun of doing it on their own, but if my question is not
understandable without this, I can of cause send it to individuals via mail.
- [Coq-Club] How to print state of SFLib Case, SCase?, michael.soegtrop, 12/12/2013
- Re: [Coq-Club] How to print state of SFLib Case, SCase?, Laurent Théry, 12/12/2013
- Message not available
- RE: [Coq-Club] How to print state of SFLib Case, SCase?, Soegtrop, Michael, 12/13/2013
