coq-club - Re: [Coq-Club] How to print state of SFLib Case, SCase?
  • To: michael.soegtrop AT intel.com
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to print state of SFLib Case, SCase?
  • Date: Thu, 12 Dec 2013 12:50:43 +0100
As an exerices I tried to do the "advanced expression simplifier" exercise in
SF Imp.v by just repeatedly trying various tacticals. This works astonishingly
well and fast (~1s for ~100 intermediate goals with 13 tactics given to try),
but it is not so easy to understand what tactics are applied to which goal in
which order. I added some idtac "description" but it would be perfect if one
could print the values of all the Case, SCase, ... annotations for each tactic
applied.
This may be of some use in your case but with idtac you can actually print value.
Ltac print_assumption H :=
let v := type of H in
idtac "type of "; idtac H; idtac " : ";
idtac v.
Goal 2 = 3 -> 3 = 4 -> 1 = 2.
intros H1 H2.
print_assumption H1.
print_assumption H2.
And another question: The list of tactics to try starts with reflexivity:
repeat (
try ( reflexivity; idtac "solved" );
but here ; idtac doesn't work, because no new goal is created, so idtac is not
executed. Is there a way to print something after a tactic which solved the
current goal?
Thanks & best regards,
Michael
P.S.: I don't want to post the solution of the exercise here so that others
are not robbed of the fun of doing it on their own, but if my question is not
understandable without this, I can of cause send it to individuals via mail.
