- To: Edwin Westbrook <westbrook AT kestrel.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] From equality of foralls to equality of their bodies
- Date: Fri, 13 Dec 2013 22:58:40 -0500
It is false, if you assume univalence. Consider A = bool, and B x = if x then True else False, and B' x = if x then False else True. Univalence gives (forall (x:A), B x) = (forall (x:A), B' x) (because they are isomorphic types; both are isomorphic to the empty set), but it is clear that we shouldn't have forall x, B x = B' x (and thus can't have (fun x => B x) = (fun x => B' x)), because True != False. Therefore, it's unprovable in vanilla Coq, and provably false in Coq + Univalence.
I'm not sure what it's status is if you have some particular axiom that contradicts univalence. (As an extreme example, you could probably take it to be true as an axiom. I don't think this is inconsistent, but it might be.)
-Jason
On Fri, Dec 13, 2013 at 9:20 PM, Edwin Westbrook <westbrook AT kestrel.edu> wrote:
Hi,
Does anyone know if the following lemma is provable in Coq? I am perfectly happy to use functional extensionality, or even stronger axioms, as I am already using informative excluded middle:
Lemma pi_eq_to_app_eq A B B' :
(forall (x:A), B x) = (forall (x:A), B' x) ->
(fun x => B x) = (fun x => B' x).
Thanks in advance!
-Eddy
- [Coq-Club] From equality of foralls to equality of their bodies, Edwin Westbrook, 12/14/2013
- Re: [Coq-Club] From equality of foralls to equality of their bodies, Jason Gross, 12/14/2013
- Re: [Coq-Club] From equality of foralls to equality of their bodies, Edwin Westbrook, 12/16/2013
- Re: [Coq-Club] From equality of foralls to equality of their bodies, Jason Gross, 12/16/2013
- Re: [Coq-Club] From equality of foralls to equality of their bodies, Anthony Bordg, 12/17/2013
