- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] An exercise in Software Foundations
- Date: Sat, 21 Dec 2013 01:25:08 +0300
No, it's not a counterexample:
Theorem example_hoare_proof :
hoare_proof example_P example_prog example_Q.
Proof.
unfold example_prog, example_P, example_Q. eapply H_Consequence.
apply (H_While (fun st => st X = 3 \/ st X = 4)). eapply
H_Consequence_pre.
apply H_Asgn.
unfold assn_sub, bassn, update. simpl. intros. inversion H.
right. apply beq_nat_true in H1. omega.
simpl. intros. omega.
unfold bassn, update. simpl. intros. inversion H. inversion H0.
rewrite not_true_iff_false in H1. apply beq_nat_false in H1.
rewrite H2 in H1. intuition.
assumption.
Qed.
My question is actually this: if {{ P }} WHILE b DO c END {{ Q }} is
valid hoare triple, does it implies, that you can prove it with
hoare_while? Since H_While is just a relation version of hoare_while.
I suppose, that you can't prove such a thing with an arbitrary loop
due to undecidability of loop's invariants inference. Am I right? Or
maybe someone has a solution to hoare_proof_complete?
2013/12/20,
vuvupik AT gmail.com
<vuvupik AT gmail.com>:
> It's in HoareAsLogic.v:
> Theorem hoare_proof_complete : forall P c Q,
> {{P}} c {{Q}} -> hoare_proof P c Q.
> By placing admit in the end of available proof, i've got this context:
> Case := "WHILE" : String.string
> b : bexp
> c : com
> IHc : forall P Q : Assertion, ({{P}} c {{Q}}) -> hoare_proof P c Q
> P : Assertion
> Q : Assertion
> HT : {{P}} WHILE b DO c END {{Q}}
> hoare_proof P (WHILE b DO c END) Q
> But isn't it a counterexample? :
> Definition example_prog :=
> WHILE BEq (AId X) (ANum 3) DO
> X ::= APlus (AId X) (ANum 1)
> END.
> Definition example_P := fun st => st X = 3.
> Definition example_Q := fun st => st X = 4.
> Theorem example_hoare_triple :
> {{ example_P }} example_prog {{ example_Q }}.
> Proof.
> unfold example_prog, example_P, example_Q, hoare_triple. intros. inversion
> H;
> subst.
> simpl in H5. rewrite H0 in H5. inversion H5.
> inversion H4. inversion H7; subst.
> rewrite <- H12. simpl. unfold update. simpl. rewrite H0.
> reflexivity.
> simpl in H11. unfold update in H11. simpl in H11. rewrite H0 in H11.
> inversion H11.
> Qed.
> Proof.
> unfold example_prog, example_P, example_Q. eapply H_Consequence_post.
> apply H_While.
> eapply H_Consequence_pre.
> apply H_Asgn.
> unfold assn_sub, bassn, update. simpl. intros. (* stuck *)
> Abort.
- [Coq-Club] An exercise in Software Foundations, vuvupik, 12/20/2013
- Re: [Coq-Club] An exercise in Software Foundations, троль, 12/20/2013
- Re: [Coq-Club] An exercise in Software Foundations, Guillaume Melquiond, 12/21/2013
- Re: [Coq-Club] An exercise in Software Foundations, троль, 12/21/2013
