- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] An exercise in Software Foundations
- Date: Sat, 21 Dec 2013 09:24:21 +0100
On 20/12/2013 23:25, троль wrote:
My question is actually this: if {{ P }} WHILE b DO c END {{ Q }} is
valid hoare triple, does it implies, that you can prove it with
hoare_while? Since H_While is just a relation version of hoare_while.
I suppose, that you can't prove such a thing with an arbitrary loop
due to undecidability of loop's invariants inference. Am I right? Or
maybe someone has a solution to hoare_proof_complete?
I can't tell about the version of Hoare logic described in Software Foundations (and as always, the devil is in the details), but what you are looking for is Cook's result about relative completeness. What he states is that, if your assertion language is rich enough to represent the sets of states of your program, then there exists an invariant such that you can prove '{p} while b ... {q}' by applying hoare_while.
The proof is straightforward: just use the assertion 'i' that represents all the pre-states of the while loop that lead to a state included in 'q'. (By hypothesis on the expressiveness of the assertion language, it exists.) It is easy to check that 'i' is indeed an invariant of your loop (it holds at the start, during, and at the end of the loop) and that 'i /\ not b -> q' holds.
It might seem magical, but there is an important point to keep in mind here: Cook proves that Hoare logic is complete (which is the solution to hoare_proof_complete) but he does not give you a way to build the actual invariants, he just proves that they exist. That's when you try to build an invariant that you encounter issues with undecidability.
Best regards,
Guillaume
- [Coq-Club] An exercise in Software Foundations, vuvupik, 12/20/2013
- Re: [Coq-Club] An exercise in Software Foundations, троль, 12/20/2013
- Re: [Coq-Club] An exercise in Software Foundations, Guillaume Melquiond, 12/21/2013
- Re: [Coq-Club] An exercise in Software Foundations, троль, 12/21/2013
