- To: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] issue with -R option
- Date: Wed, 1 Jan 2014 19:30:31 -0500
Thanks! This makes sense.
V.
On Jan 1, 2014, at 6:23 PM, Guillaume Melquiond
wrote:
> On 02/01/2014 00:14, Vladimir Voevodsky wrote:
>> This also feels like a bug.
> No, both behaviors are fine; they are intended.
> When you execute "coqc what/ever/a", the resulting module is just "a". So
> if you import "something.a", you get a mismatch.
> When you execute "coqc -R . something what/ever/a", the resulting module is
> "something.what.ever.a".
> And if you execute "coqc -R what something what/ever/a", the resulting
> module is "something.ever.a". So, in your case, you want to use "coqc -R
> Test Test Test/a" so that the resulting module is "Test.a".
> Best regards,
> Guillaume
- [Coq-Club] issue with -R option, Vladimir Voevodsky, 01/02/2014
- Re: [Coq-Club] issue with -R option, Guillaume Melquiond, 01/02/2014
- Re: [Coq-Club] issue with -R option, Vladimir Voevodsky, 01/02/2014
