- To: Coq Club <coq-club AT inria.fr>
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>
- Subject: [Coq-Club] issue with -R option
- Date: Wed, 1 Jan 2014 18:14:23 -0500
Hello,
here is another example of Coq behavior which I do not understand.
I have a file a.v in subdirectory Test/ and a file b.v in the main directory
which starts with the line
Require Import Test.a.
I try two things:
1. I compile a.v from the main directory with the command:
coqc Test/a
Then when I try to go over the first line of b.v I get the error message
saying that the file Test/a.vo contains library a and not library Test.a
2. I compile a.v from the main directory with the command:
coqc -R . Test Test/a
saying that the file Test/a.vo contains library Test.Test.a and not library
Test.a
This also feels like a bug.
Vladimir.
- [Coq-Club] issue with -R option, Vladimir Voevodsky, 01/02/2014
- Re: [Coq-Club] issue with -R option, Guillaume Melquiond, 01/02/2014
- Re: [Coq-Club] issue with -R option, Vladimir Voevodsky, 01/02/2014
