- To: Bill Richter <richter AT math.northwestern.edu>
- Cc: Stéphane Glondu <steph AT glondu.net>, michael.ganem AT gmail.com, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Compilation of CoQ on Linux
- Date: Sun, 5 Jan 2014 21:52:38 -0500
You haven't given enough information for most of us to have any idea how to help you. Try pasting the full output of the following commands, to be run in the source directory of Coq (you seem to be calling it /coq?):
uname -a
./configure
and then run `make clean` and then run `make VERBOSE=1`, and paste the last 10-15 lines of output here. I suspect something went wrong in your ./configure process, so seeing the output of that might help diagnose the error.
Also, is this coq-8.4pl3.tar.gz exactly as downloaded from the website, or did you try to apply Vladimir's patches (necessary for his foundations library)? If you tried to apply his patches, I expect the problem is that his patches are for Coq 8.3, not 8.4. If you haven't, then I hope that the output from ./configure will help.
-Jason
On Sun, Jan 5, 2014 at 2:04 PM, Bill Richter <richter AT math.northwestern.edu> wrote:
What version of Coq are you trying to compile? Which distributionStéphane, I'm sorry for not including that. I think I'm using Coq 8.4pl3, which I downloaded as
are you running?
coq-8.4pl3.tar.gz.
Best,
Bill
- [Coq-Club] Compilation of CoQ on Linux, michael.ganem, 01/04/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Stéphane Glondu, 01/05/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/05/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Jason Gross, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Vladimir Voevodsky, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/10/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/11/2014
- Message not available
- Re: [Coq-Club] Compilation of CoQ on Linux, Michael Ganem, 01/13/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/14/2014
