- To: Stéphane Glondu <steph AT glondu.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Compilation of CoQ on Linux
- Date: Mon, 13 Jan 2014 10:15:05 +0200
Hi Stephane,
Good news. I managed to fully install the system in byte code mode (I did not try native compilation again) without the -local flag.
I follow the regular flow but just set as you suggested the env variable CAML_LD_LIBRARY_PATH to be the full path of kernel/byterun after running ./configure -byte-only. The compilation then passes and I manage to install the system. I did no fully test the system but looks good so far.
Thanks!
Michael
On 01/10/2014 04:14 PM, Stéphane Glondu wrote:
Le 07/01/2014 21:00, Michael Ganem a écrit :
Looks much better when adding -local and compiling in byte code. I thinkYou are not supposed to do "make install" with -local. Nor should you
that the compilation completes correctly:
OCAMLC ide/coqide_ui.ml <http://coqide_ui.ml>
OCAMLC ide/coqide.mli
OCAMLC ide/coqide.ml <http://coqide.ml>
OCAMLC -a -o ide/ide.cma
OCAMLC -o bin/coqide.byte
cd bin && ln -sf coqide.byte coqide
make[1]: Leaving directory `/coq'
But now, I got a failure when running make install:
run it as root. Just directly run e.g. bin/coqtop. You might need to set
CAML_LD_LIBRARY_PATH to the full path of the directory containing
dllcoqrun.so (in kernel/byterun IIRC).
PS: please avoid sending private replies and send them to the
mailing-list so that everyone can enjoy them.
Cheers,
- Re: [Coq-Club] Compilation of CoQ on Linux, (continued)
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/05/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Jason Gross, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Vladimir Voevodsky, 01/06/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/10/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/11/2014
- Message not available
- Re: [Coq-Club] Compilation of CoQ on Linux, Michael Ganem, 01/13/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Bill Richter, 01/14/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Ben Horsfall, 01/14/2014
- Re: [Coq-Club] Compilation of CoQ on Linux, Vladimir Voevodsky, 01/14/2014
