Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Thu, 09 Jan 2014 11:28:51 +0100
Hi. Le 08/01/2014 22:19, Matthieu Sozeau a
écrit :
I have the same question, when I looked into it it
seemed like measuring every data type like this would involve
representing ordinals not just naturals... and then which ones... Maybe
you can translate a (nat -> I) -> I constructor to (nat
-> I i) -> I (^ i) ?
Right. Andreas gave us a similar example on the HoTT list in his
extension of Agda with size annotations. But, for proving
termination, you just need the successor symbol ^ and the subterm
relation ^x > x. There is no need to represent ordinals.Then you'd want an (implicit?) subtyping from I i to I j for j > i ? This is indeed necessary for typing a match whose branches have different sizes. But there is no subtyping in Coq (except on universes)... Note also that size decreasingness is not sufficient for having termination. When defining f:I i->T, where T may depend on i in general, you need T(i) to satisfy additional conditions of monotony or continuity wrt i. See Andreas' work on this subject. Best regards, Frédéric. -- Matthieu Le mercredi 8 janvier 2014, Frédéric Blanqui a écrit :
Le 08/01/2014 19:18, Cody Roux a écrit : > On 01/08/2014 12:49 PM, Jean Goubault-Larrecq wrote: >> That sounds fair. A couple years ago, I tried seeing if there was >> a straightforward way to perform this translation (with Jorge >> Sacchini). It's not trivial, and in particular I found that I would >> probably need some form of proof-irrelevance, even for >> "first-order" datatypes, which seems ironic. However in this case >> we would only need it on "h-level 0" so it doesn't seem hopeless. >> >> Higher-order datatypes are a bit more difficult, and I admit I >> never worked it out. I believe it's possible though. >> >>>> The eliminators are like axioms in set theory and it is >>>> worthwhile to translate any extension by reducing them to the >>>> axiom instead of adding new ones even though they may be >>>> semantically justified. >>> That's fair, but I don't see why eliminators have a more powerful >>> ontological status than sized-types. They require work to be >>> derived as well, and the correctness proofs for them are quite >>> similar to that for sized types. This seems like a matter of >>> preference. Obviously I'm not neutral in this matter though. >> I'm no Coq expert, but wasn't this idea of translating >> pattern-matching to eliminators (recursors) already >> the core of Cristina Cornes' PhD thesis, back in the >> time where Coq only had recursors and no pattern-matching? >> I seem to recall she had already realized the difficulty >> of the task, and the importance of axiom K, at least. > I'm afraid I'm not aware of Cristina's work. I'll try to read up on this. > > Here is the situation as I understand it. As with most falls from grace, > Coq started from a place without sin, namely with a rather hard to use > guard system based on Gimenez's (hard to find) paper "Codifying guarded > definitions with recursive schemes", in which every definition could (in > principle) be translated back into the recursors from whence they came. > Over time, the guard condition was relaxed to allow for more flexible > definition, and the direct correspondence was lost. > > What I was referring to was more specific to sized-types. In principle > it is possible to take this powerful extension of the guard condition, > and use it to translate back into a system with only recursors. However, > this requires a change to the definition of the inductive types, so it > isn't as straightforward as the Gimenez translation. In particular, > Lists would become size-indexed lists (vectors), and any fixpoint > definition over lists would actually involve the fix-point combinator, > definable in terms of recursors/eliminators: > > Fix : (forall n, (forall m < n, List m -> T) -> (List n -> T)) -> forall > n, List n -> T > > Where n, m are natural numbers (the "skeleton" of List). I think I can > define such a modified inductive type for every instance of inductive > definitions in Coq. This would certainly revert us back to the sinless > state desired by Thorsten and Vladimir, while preserving the paradise > offered by the relaxed guard condition. Including strictly positive inductive types, that is, with constructors taking functions as recursive arguments? > About K: Coq has managed to describe a pattern-match which does not > allow it (by making less unification information available in the > branches), and I don't think it's that relevant to the problem at hand, > which is mostly concerned about when a term is a subterm of another. > > Best, > > > Cody > >> All the best, >> >> - -- Jean. >> >> >> -----BEGIN PGP SIGNATURE----- >> Version: GnuPG/MacGPG2 v2.0.18 (Darwin) >> Comment: GPGTools - http://gpgtools.org >> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/ >> >> iQEcBAEBAgAGBQJSzY/DAAoJEBO3J6HB7Rh1WyUH/3uim2ZTsfzddH0gbCngNeFu >> vqnvXmd8VPKNoH4LE9Ydhi2J4ibCmnyPH2sFi1ee6t5Kt9Oz8GhOc7HzRdlB2qsq >> GpD+lxDE8I9HdokfDyYnP2RP2ZiUs2/2m1bcAJkWVZLwlcKyKiwr/yzY/lNdSIRS >> J/YYIXMI/wCw1b38ZoFXvaa0okOS8IDDde2W1lybvRSO0F1ZO6qMzWwas5hD78mC >> FU8MeU7xYvWOv30GRyYEl0PaUswCmmGhvVqZDH0Ttum2ONnQpQ9JhMKB6AaVZQu/ >> hB7/PE8vOXCFLBUMkBTfn/R655VHbs87tytgMLKE5Q+eMs5hA7u3lfEMIzzP+io= >> =JLKR >> -----END PGP SIGNATURE----- -- -- Matthieu |
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, (continued)
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Prof. Robert Harper, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jean Goubault-Larrecq, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/08/2014
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/08/2014
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/09/2014
- RE: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Nikhil Swamy, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Andreas Abel, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jorge Luis Sacchini, 01/10/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jean Goubault-Larrecq, 01/09/2014
