coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Martin Escardo <m.escardo AT cs.bham.ac.uk>, Frédéric Blanqui <frederic.blanqui AT inria.fr>, "<coq-club AT inria.fr>" <coq-club AT inria.fr>, "<homotopytypetheory AT googlegroups.com>" <homotopytypetheory AT googlegroups.com>, "<agda AT lists.chalmers.se>" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Tue, 7 Jan 2014 13:23:53 -0500
that would be an application of markov's principle, i think, which would in
effect add a new form of function of Pi-Sigma type. andrej most probably
knows the implications of this. hugo herbelin has written about it recently,
but i am not familiar with the result off the top of my head.
bob
Sent from tablet
> On Jan 7, 2014, at 9:39, Vladimir Voevodsky
> wrote:
> BTW what the general theory says about applying classical logic for
> termination checking? Can this be sensibly expressed in the eliminator
> language?
> V.
>> On Jan 7, 2014, at 6:36 AM, Martin Escardo
>> wrote:
>>> On 07/01/14 10:01, Frédéric Blanqui wrote:
>>> Nowadays, one can automatically certify in proof assistants like Coq or
>>> Isabelle/HOL quite complex termination proofs (see the website of the
>>> termination competition http://termcomp.uibk.ac.at/termcomp/home.seam).
>>> So, it would be a pity not to take advantage of this for making the life
>>> of proof assistants users easier, and allow them to define functions (or
>>> enrich the equivalence on types) in ways that can hardly (or cannot) be
>>> translated into eliminators. This is for instance the case of function
>>> definitions based on general rewriting theory. This of course may raise
>>> problems for making sure that such definitions are consistent, but it is
>>> another (interesting) problem.
>> The problem is that if you accept general recursive terminating
>> definitions, you are in fact realizing new axioms that are not
>> available in MLTT.
>> For example, once I and Paulo Oliva defined Bar Recursion in Agda (by
>> disabling non-termination checking in a short module) to realize the
>> Double Negation Shift (DNS), and used this to prove a form of the
>> Infinite Pigeonhole Principle, so that canonicity for ground types is
>> retained.
>> However, the DNS is certainly *not* provable in MLTT (in any of its
>> flavours).
>> Similarly, you can realize other principles by having general
>> recursion, such as the uniform continuity (UC) of all functions
>> (N->Bool)->N.
>> And so on.
>> Even assuming that this wouldn't violate consistency, you have a
>> problem: while UC may be consistent with Univalence (UA), it certainly
>> negates excluded middle, and the HoTT people want HoTT to be
>> compatible with excluded middle (EM), and with choice too (AC), which
>> it is, but not if you add something like UC.
>> I am not saying that your termination checker will be able to check
>> the termination of UC. But it may check the termination of a realizer
>> of an axiom that contradicts EM or AC, or even UA.
>> Also, even if you forget about HoTT, it is not clear what new axioms
>> you are adding when you allow general recursion, and the supply of new
>> axioms you get will (necessarily) depend on the particularities of
>> your termination checker (as there is no general termination checker),
>> and so we won't be sure precisely what axioms we are adding to
>> MLTT in this way.
>> That's why, as Thorsten says, it would be very good to have as a
>> meta-theorem that any termination-checked Agda program can be
>> in principle translated to eliminators (even if we decide not to do
>> that in practice).
>> M.
>> _______________________________________________
>> Agda mailing list
>> Agda AT lists.chalmers.se
>> https://lists.chalmers.se/mailman/listinfo/agda
> You received this message because you are subscribed to the Google Groups
> "Homotopy Type Theory" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to
> HomotopyTypeTheory+unsubscribe AT googlegroups.com.
> For more options, visit https://groups.google.com/groups/opt_out.
