- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] guarantees from Print Assumptions
- Date: Fri, 10 Jan 2014 07:19:45 +0100
I think Print Assumption is conservative: if there is an axiom you will see some axioms. However, as it happens, modules make things complicated. The version I first wrote basically ignored module, and in some circumstances reported way to many axioms. I think it was something about modules with abstract interfaces. Anyway, Pierre Letouzey wrote a significantly more extensive version which deals with modules. It may still raise too many axioms (non-axioms may mask other axioms), but not as often.
Anyway, I believe you can trust the "Closed under the global context" assertion (otherwise you have found a real bug).
Arnaud
On 9 January 2014 21:09, Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
Suppose I prove some theorem(say T) and then Print Assumptions T says:"Closed under the global context".Can I then be sure that the proof does not (possibly indirectly) depend on someunproved assumptions(Axioms, Admits)?I'm not sure if I was dreaming, but I think that once Print Assumptions said that on a lemmawhose proof used other lemmas whose proofs had admits in them.I can't replicate that problem today.-- Abhishekhttp://www.cs.cornell.edu/~aa755/
- [Coq-Club] guarantees from Print Assumptions, Abhishek Anand, 01/09/2014
- Re: [Coq-Club] guarantees from Print Assumptions, Arnaud Spiwack, 01/10/2014
- Re: [Coq-Club] guarantees from Print Assumptions, Abhishek Anand, 01/14/2014
