coq-club - Re: [Coq-Club] guarantees from Print Assumptions
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] guarantees from Print Assumptions
  • Date: Tue, 14 Jan 2014 00:39:54 -0500
Thanks for that reassurance.
I'm pretty sure now that what I observed was NOT a bug in Print Assumptions.
Instead, I was being stupid and thinking that a proof was using a lemma when it was not.
Sorry.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Fri, Jan 10, 2014 at 1:19 AM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
I think Print Assumption is conservative: if there is an axiom you will see some axioms. However, as it happens, modules make things complicated. The version I first wrote basically ignored module, and in some circumstances reported way to many axioms. I think it was something about modules with abstract interfaces. Anyway, Pierre Letouzey wrote a significantly more extensive version which deals with modules. It may still raise too many axioms (non-axioms may mask other axioms), but not as often.
Anyway, I believe you can trust the "Closed under the global context" assertion (otherwise you have found a real bug).
Arnaud
On 9 January 2014 21:09, Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
Suppose I prove some theorem(say T) and then Print Assumptions T says:
"Closed under the global context".
Can I then be  sure that the proof does not (possibly indirectly) depend on some
unproved assumptions(Axioms, Admits)?
I'm not sure if I was dreaming, but I think that once Print Assumptions said that on a lemma
whose proof used other lemmas whose proofs had admits in them.
I can't replicate that problem today.
