- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market
- Date: Wed, 15 Jan 2014 00:19:33 +0200
https://proofmarket.org/problem/view/19
In this problem I have found related function in closed form:
Definition tak' x y z :=
if Z_le_dec x y
then z
else if Z_le_dec z x
then if Zeven_odd_dec (y-x)
then if Z_le_dec (z+2) y
then z+1
else y
else y
else if Z.eq_dec y (x-1)
then x
else if Z.eq_dec z (x+1)
then y
else if Zeven_odd_dec (z-x)
then x
else y+1.
Proofs of properties here (lots of time are needed on slow computers, as mine, for example):
Theorem thm1 x y z: x <= y -> tak' x y z = z.
intros; unfold tak'; destruct Z_le_dec; omega.
Qed.
Ltac parity_tac := match goal with
| x: Zeven _ |- _ => apply Zeven_ex_iff in x; destruct x; parity_tac
| x: Zodd _ |- _ => apply Zodd_ex_iff in x; destruct x; parity_tac
| _ => idtac
end.
Theorem thm2 x y z: y < x -> tak' x y z = tak' (tak' (x-1) y z) (tak' (y-1) z x) (tak' (z-1) x y).
repeat (destruct Z_le_dec; try omega);
repeat (destruct Z.eq_dec; try omega);
repeat (destruct Zeven_odd_dec; try omega); parity_tac; omega.
Qed.
Is it possible use this result to prove theorem tak_terminates? In some simple way?
Or more general question? Is it possible to prove termination (similarly to the problem) if I have corresponding function with all required recursive equations proved?
- [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Ilmārs Cīrulis, 01/14/2014
- Re: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Wojciech Jedynak, 01/15/2014
- Re: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Ilmārs Cīrulis, 01/18/2014
