- To: Wojciech Jedynak <wjedynak AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market
- Date: Sat, 18 Jan 2014 19:50:40 +0200
This is what I have done yet. (Not much because of laziness.)
Require Import ZArith.
Open Scope Z.
Definition tak' x y z :=
if Z_le_dec x y
then z
else if Z_le_dec z x
then if Zeven_odd_dec (y-x)
then if Z_le_dec (z+2) y
then z+1
else y
else y
else if Z.eq_dec y (x-1)
then x
else if Z.eq_dec z (x+1)
then y
else if Zeven_odd_dec (z-x)
then x
else y+1.
Ltac parity_tac := match goal with
| x: Zeven _ |- _ => apply Zeven_ex_iff in x; destruct x; parity_tac
| x: Zodd _ |- _ => apply Zodd_ex_iff in x; destruct x; parity_tac
| _ => idtac
end.
Ltac D := unfold tak'; repeat (destruct Z_le_dec; try omega);
repeat (destruct Z.eq_dec; try omega);
repeat destruct Zeven_odd_dec; parity_tac; try omega.
Inductive tak : Z -> Z -> Z -> Z -> Prop :=
| tak_base : forall x y z, x <= y -> tak x y z z
| tak_call : forall x y z a b c r,
y < x ->
tak (x-1) y z a ->
tak (y-1) z x b ->
tak (z-1) x y c ->
tak a b c r ->
tak x y z r.
Theorem T_base x y z r: x<=y -> r=z -> tak x y z r.
intros; D. rewrite H0; apply tak_base; auto.
Qed.
Theorem T0 x y z r: y<x -> z-1<=y<=z+1 -> r=y -> tak x y z r.
intros. assert (r=tak' x y z) by (D; auto). rewrite H2.
intros.
apply Zlt_lower_bound_ind with (z:=y+1)(x:=x); [|omega]; intros.
apply tak_call with (a:=tak' (x0-1) y z) (b:=tak' (y-1) z x0) (c:=tak' (z-1) x0 y);
try omega; D; try (apply tak_base; omega);
assert (y = tak' (x0-1) y z) by (D; auto); rewrite H6 at -1; apply H3; omega.
Qed.
Theorem T1 x y z r: y=x-1 -> z>=x+1 -> r=x -> tak x y z r.
intros. rewrite H1.
apply tak_call with (a:=tak' (x-1) y z)(b:=tak' (y-1) z x)(c:=tak' (z-1) x y);
try omega; D; try (apply tak_base; omega); apply T0; omega.
Qed.
Lemma Termination1 x y z r: y<x -> r=tak' x y z -> tak x y z r.
intros. rewrite H0.
apply Zlt_lower_bound_ind with (z:=y+1)(x:=x). 2: omega. intros.
apply tak_call with (a:=tak' (x0-1) y z) (b:=tak' (y-1) z x0) (c:=tak' (z-1) x0 y); D;
try (apply T_base; omega); try (apply T0; omega); try (apply T1; omega).
(* this can be automatised too *)
assert (z+1=tak' (x0-1) y z) as X by D; rewrite X; apply H1; omega.
assert (y=tak' (x0-1) y z) as X by D; rewrite X at -1; apply H1; omega.
assert (x0-1=tak' (x0-1) y z) as X by D; rewrite X at -1; apply H1; omega.
assert (y+1=tak' (x0-1) y z) as X by D; rewrite X; apply H1; omega.
(* with 5 cases left *)
In some future I will try to find and use some more useful induction, maybe copying from Wojciech's proof. :)
On Wed, Jan 15, 2014 at 1:22 AM, Wojciech Jedynak <wjedynak AT gmail.com> wrote:
Hello,
yes! I actually tried this approach two days ago and succeded, but now
> Is it possible use this result to prove theorem tak_terminates? In some
> simple way? Or more general question? Is it possible to prove termination (similarly to the problem) if I have > corresponding function with all required recursive equations proved?
I'm waiting for the proof market to accept solutions again. I'm not so
sure about the simple part, though -- I found a nice measure by
analyzing relation between the depth of the recursion and the inputs.
I didn't use the _dec functions in the def. of tak0, but instead
relied on e.g. <=?, so that could simplify my proof.
Best,
Wojciech
- [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Ilmārs Cīrulis, 01/14/2014
- Re: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Wojciech Jedynak, 01/15/2014
- Re: [Coq-Club] Question about (proved) Takeuchi problem from Proof Market, Ilmārs Cīrulis, 01/18/2014
