coq-club - [Coq-Club] Stack overflow with byte code compilation
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Stack overflow with byte code compilation
  • Date: Sun, 19 Jan 2014 09:38:57 +0200
Hi,
I try to run the following:
Definition computation1 :=
  (fun f h p => f (f (f h)) p)
    (fun g p => g (g p))
    (fun p => match p with (x, y) => (x+1, (x+1) * y) end)
    (0, 1).
Compute computation1.
on a Ubuntu machine. In this machine, Coq is compiled in byte code.
And I got "Stack overflow."
I try:
  1. This calculation on another machine where Coq is compiled in native and it is ok.
  2. In the same machine than 1, I compile Coq in byte code and got also "Stack overflow." on the  calculation.
  3. In the original machine, I try to increase the stack limit using : ulimit -s 32000 and still the same problem.
The original machine is a ubuntu/ARM and the second machine is ubuntu/x86.
I did not manage to compile in native mode Coq on my original machine that s why I compiled it in byte code.
The problem seems to be linked to byte code compilation.
Has anyone a tip for this?
thanks,
Michael
