- To: Michael Ganem <michael.ganem AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Stack overflow with byte code compilation
- Date: Mon, 20 Jan 2014 08:34:43 -0500 (EST)
The problem is not bytecode, but the computation with unary numbers. The
output of your expression should be (8, 40320): this second number in unary
is... big. The computations to produce it will blow out the stack. Try using
BinNat for more compact representation.
-Ian
----- Original Message -----
To:
Sent: Sunday, January 19, 2014 2:38:57 AM GMT -05:00 US/Canada Eastern
Subject: [Coq-Club] Stack overflow with byte code compilation
Hi,
I try to run the following:
Definition computation1 :=
(fun f h p => f (f (f h)) p)
(fun g p => g (g p))
(fun p => match p with (x, y) => (x+1, (x+1) * y) end)
(0, 1).
Compute computation1.
on a Ubuntu machine. In this machine, Coq is compiled in byte code.
And I got "Stack overflow."
I try:
1. This calculation on another machine where Coq is compiled in native
and it is ok.
2. In the same machine than 1, I compile Coq in byte code and got also
"Stack overflow." on the calculation.
3. In the original machine, I try to increase the stack limit using :
ulimit -s 32000 and still the same problem.
The original machine is a ubuntu/ARM and the second machine is ubuntu/x86.
I did not manage to compile in native mode Coq on my original machine that s
why I compiled it in byte code.
The problem seems to be linked to byte code compilation.
Has anyone a tip for this?
thanks,
Michael
- [Coq-Club] Stack overflow with byte code compilation, Michael Ganem, 01/19/2014
- Re: [Coq-Club] Stack overflow with byte code compilation, J. Ian Johnson, 01/20/2014
- Re: [Coq-Club] Stack overflow with byte code compilation, Arnaud Spiwack, 01/20/2014
