- From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
- To: Julien Forest <julien.forest AT ensiie.fr>
- Cc: Abhishek Anand <abhishek.anand.iitg AT gmail.com>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Guarded command
- Date: Mon, 20 Jan 2014 16:19:43 +0000
- Accept-language: en-GB, en-US
Thanks for all your comments. They were very helpful.
The problem I'm trying to solve is more like the one below, in which C is
built from option C and list A, and A is built from C. I've tried proving
L_aux in the same way as before but I didn't get very far. Any help would be
most appreciated. Thanks.
Require Import List.
Inductive C : Set :=
Build_C : option C -> list A -> C
with A : Set :=
Build_A : C -> A.
Fixpoint size (c : C) : nat :=
match c with Build_C o la =>
(fix f (l : list A) : nat :=
match l with |
nil => 0 |
a :: l' =>
match a with
Build_A c' => S (size c')
end + f l'
end) la
match o with |
None => 0 |
Some c' => S (size c')
end
end.
Fixpoint F (c : C) : Prop :=
(fix f (l : list A) : Prop :=
match l with |
nil => True |
a :: l' =>
match a with
Build_A c' => F c'
end /\ f l'
end) la
match o with |
None => True |
Some c' => F c'
end
end.
Lemma L_aux : forall n : nat, forall c : C, size c = n -> F c.
Proof.
induction n.
intros c Heq.
destruct c.
destruct o.
inversion Heq.
induction l.
inversion H0.
<stuck>
Lemma L : forall c : C, F c.
Regards,
Jeff.
On 20 Jan 2014, at 13:21, Julien Forest wrote:
> Or you cqn simply use Function to define F which, in particular,
> produces the induction principle attached to your function F leading to
> a quite trivial proof as below :
> Build_C : option C -> C.
> Function F (c : C) : Prop :=
> match c with |
> Build_C None => True |
> Build_C (Some c') => F c'
> end.
> Proof.
> intros c;functional induction (F c).
> - exact I.
> - assumption.
> Qed.
> Hope this helps even if not answer you first question.
> Best regards,
> Julien Forest
> On Sun, 19 Jan 2014 16:25:09 -0500
> Abhishek Anand
> wrote:
>> In this case, you can easily define a size function and do induction
>> on size.
>> Fixpoint size (c: C):=
>> match c with
>> | Build_C (Some cc) => 1+ size cc
>> | Build_C None => 0
>> end.
>> match c with |
>> end.
>> Lemma L_aux : forall n c, size c = n -> F c.
>> Proof.
>> induction n; intros c Heq; destruct c; destruct o; inversion Heq;
>> simpl; auto.
>> Qed.
>> Proof.
>> intro c.
>> pose proof (L_aux (size c) c).
>> auto.
>> Qed.
>> -- Abhishek
>> http://www.cs.cornell.edu/~aa755/
>> On Sun, Jan 19, 2014 at 3:55 PM, Terrell, Jeffrey
>>> wrote:
>>> Thanks for the advice. I'm using [fix] because I don't know how to
>>> prove lemmas of this kind by [induction]. Would you mind jotting
>>> the proof down for me? Thanks.
>>> Regards,
>>> Jeff.
>>> On 19 Jan 2014, at 19:34, Abhishek Anand wrote:
>>> On Sun, Jan 19, 2014 at 1:49 PM, Terrell, Jeffrey <
>>> wrote:
>>>> Hi,
>>>> In the manual, it says that [Guarded] verifies that the guard
>>>> condition hasn't been violated at some point in a proof.
>>>> 1. What does that mean in the context of the following example?
>>>> 2. Why does the first [Guarded] fail?
>>>> 3. Is [Guarded] automatically called by [Qed]?
>>>> 4. Presumably, [Guarded] can be used to debug a proof based on
>>>> [fix]. However, is there another, possibly better, way?
>>>> My opinion is that using induction principle of the type of the
>>> decreasing argument is a much better way than fix.
>>> I think that if you never use fix and cofix, you never have to
>>> worry about your proof being rejected at Qed time.
>>> Many people hate the idea of proofs being rejected at Qed time.
>>> Also, opaqe definitions can lead to rejection of legitimate
>>> proofs(I observed that with cofix).
>>> Once, Coq did not give us the desired induction principle when we
>>> defined an inductive type. The first thing we did was to use fix to
>>> prove the induction principle and then we never used fix after that.
>>>> Thanks.
>>>> match c with |
>>>> end.
>>>> Proof.
>>>> fix H 1.
>>>> (* Guarded - Fails *)
>>>> intro c.
>>>> Guarded.
>>>> destruct c as [o].
>>>> Guarded.
>>>> destruct o as [| c'].
>>>> Guarded.
>>>> unfold F.
>>>> Guarded.
>>>> exact (H c).
>>>> Guarded.
>>>> unfold F.
>>>> Guarded.
>>>> trivial.
>>>> Qed.
>>>> Regards,
>>>> Jeff.
- [Coq-Club] Guarded command, Terrell, Jeffrey, 01/19/2014
- Re: [Coq-Club] Guarded command, Abhishek Anand, 01/19/2014
- Re: [Coq-Club] Guarded command, Terrell, Jeffrey, 01/19/2014
- Re: [Coq-Club] Guarded command, Adam Chlipala, 01/19/2014
- Re: [Coq-Club] Guarded command, Julien Forest, 01/20/2014
- Re: [Coq-Club] Guarded command, Terrell, Jeffrey, 01/20/2014
- Re: [Coq-Club] Guarded command, Abhishek Anand, 01/20/2014
