coq-club - Re: [Coq-Club] Guarded command
  • To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • Cc: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Guarded command
  • Date: Mon, 20 Jan 2014 14:21:23 +0100
Or you cqn simply use Function to define F which, in particular,
produces the induction principle attached to your function F leading to
a quite trivial proof as below :
Inductive C : Set :=
Build_C : option C -> C.
Function F (c : C) : Prop :=
match c with |
Build_C None => True |
Build_C (Some c') => F c'
end.
Lemma L : forall c : C, F c.
Proof.
intros c;functional induction (F c).
- exact I.
- assumption.
Qed.
Hope this helps even if not answer you first question.
Best regards,
Julien Forest
On Sun, 19 Jan 2014 16:25:09 -0500
Abhishek Anand
wrote:
> In this case, you can easily define a size function and do induction
> on size.
> Fixpoint size (c: C):=
> match c with
> | Build_C (Some cc) => 1+ size cc
> | Build_C None => 0
> end.
> Fixpoint F (c : C) : Prop :=
> match c with |
> end.
> Lemma L_aux : forall n c, size c = n -> F c.
> Proof.
> induction n; intros c Heq; destruct c; destruct o; inversion Heq;
> simpl; auto.
> Qed.
> Proof.
> intro c.
> pose proof (L_aux (size c) c).
> auto.
> Qed.
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
> On Sun, Jan 19, 2014 at 3:55 PM, Terrell, Jeffrey
> > wrote:
> > Thanks for the advice. I'm using [fix] because I don't know how to
> > prove lemmas of this kind by [induction]. Would you mind jotting
> > the proof down for me? Thanks.
> > Regards,
> > Jeff.
> > On 19 Jan 2014, at 19:34, Abhishek Anand wrote:
> > On Sun, Jan 19, 2014 at 1:49 PM, Terrell, Jeffrey <
> > wrote:
> >> Hi,
> >> In the manual, it says that [Guarded] verifies that the guard
> >> condition hasn't been violated at some point in a proof.
> >> 1. What does that mean in the context of the following example?
> >> 2. Why does the first [Guarded] fail?
> >> 3. Is [Guarded] automatically called by [Qed]?
> >> 4. Presumably, [Guarded] can be used to debug a proof based on
> >> [fix]. However, is there another, possibly better, way?
> >> My opinion is that using induction principle of the type of the
> > decreasing argument is a much better way than fix.
> > I think that if you never use fix and cofix, you never have to
> > worry about your proof being rejected at Qed time.
> > Many people hate the idea of proofs being rejected at Qed time.
> > Also, opaqe definitions can lead to rejection of legitimate
> > proofs(I observed that with cofix).
> > Once, Coq did not give us the desired induction principle when we
> > defined an inductive type. The first thing we did was to use fix to
> > prove the induction principle and then we never used fix after that.
> >> Thanks.
> >> match c with |
> >> end.
> >> Proof.
> >> fix H 1.
> >> (* Guarded - Fails *)
> >> intro c.
> >> Guarded.
> >> destruct c as [o].
> >> Guarded.
> >> destruct o as [| c'].
> >> Guarded.
> >> unfold F.
> >> Guarded.
> >> exact (H c).
> >> Guarded.
> >> unfold F.
> >> Guarded.
> >> trivial.
> >> Qed.
> >> Regards,
> >> Jeff.
