- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] coqdoc inconsistent colors
- Date: Mon, 20 Jan 2014 18:18:45 -0500
The coqdoc manual says:
Coq material is quoted between the delimiters [ and ]
Suppose I define an Inductive type
Inductive Void := .
When I generated the latex file using coqdoc, this occurrence of
Void exported to latex as \coqdocinductive{Void}
Hence it is colored correctly.
However, if I refer to it later in comments:
(** [Void] denotes the false proposition *)
this occurrence gets exported to latex as \coqdocvar{Void}.
I was expecting it to be exported as \coqdocinductive{Void} to be consistent.
Am I doing something wrong?
Or it was supposed to work in this (inconsistent) way?
If so, why would one want to use this [] feature?
-- Abhishek
http://www.cs.cornell.edu/~aa755/- [Coq-Club] coqdoc inconsistent colors, Abhishek Anand, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Matthieu Sozeau, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Abhishek Anand, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Pierre Boutillier, 01/22/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Matthieu Sozeau, 01/22/2014
