- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coqdoc inconsistent colors
- Date: Tue, 21 Jan 2014 13:23:41 -0500
Thanks Matthieu. That would definitely help a lot.
However, our comments sometimes also refer to definitions of earlier files.
Is there a way to get --interpolate to work even if the identifier was
declared in a different file that is included using Require Import/ Export?
Basically, coqdoc could issue a Locate command to coqtop
for the identifier at the point it occurs in a comment
and use its output to determine the classification.
Does coqdoc already invoke coqtop?
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Tue, Jan 21, 2014 at 2:20 AM, Matthieu Sozeau <mattam AT mattam.org> wrote:
The --interpolate option will try to typeset the identifier with the most recent classification for it (in the same file), that's probably what you want.
Le lundi 20 janvier 2014, Abhishek Anand <abhishek.anand.iitg AT gmail.com> a écrit :
The coqdoc manual says:Coq material is quoted between the delimiters [ and ]Suppose I define an Inductive typeInductive Void := .When I generated the latex file using coqdoc, this occurrence ofVoid exported to latex as \coqdocinductive{Void}
Hence it is colored correctly.However, if I refer to it later in comments:(** [Void] denotes the false proposition *)this occurrence gets exported to latex as \coqdocvar{Void}.
I was expecting it to be exported as \coqdocinductive{Void} to be consistent.Am I doing something wrong?Or it was supposed to work in this (inconsistent) way?If so, why would one want to use this [] feature?-- Abhishekhttp://www.cs.cornell.edu/~aa755/
-- Matthieu
- [Coq-Club] coqdoc inconsistent colors, Abhishek Anand, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Matthieu Sozeau, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Abhishek Anand, 01/21/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Pierre Boutillier, 01/22/2014
- Re: [Coq-Club] coqdoc inconsistent colors, Matthieu Sozeau, 01/22/2014
