coq-club - [Coq-Club] Recursion Specification Problem
  • From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Recursion Specification Problem
  • Date: Wed, 29 Jan 2014 11:33:11 +0000
  • Accept-language: en-GB, en-US
I'm having difficult writing a recursive specification that would generate the nested set of match statements below. The problem is that I want to reason about the original value of c whenever the recursion terminates, and not the current value of c. For example, in the inr p3 branch, I want to reason about c1, not c3; and in the inr p2 branch, I want to reason about c1, not c2; and so on.
Any help would be much appreciated. Thanks.
Require Import List.
Inductive C : Set :=
   Build_C : list A -> C
with A : Set :=
   Build_A : C + P -> A
with P : Set :=
   Build_P : P.
Inductive T : Set :=
   Build_T : list U -> T
with U : Set :=
   Build_U : U.
Variable f : C -> list U.
Variable c1 : C.
Check
(* 1 *)
match c1 with Build_C la1 =>
   forall a1 : A, In a1 la1 ->
      match a1 with Build_A cp1 =>
         match cp1 with
            inl c2 =>
               (* 2 *)
               match c2 with Build_C la2 =>
                  forall a2 : A, In a2 la2 ->
                     match a2 with Build_A cp2 =>
                        match cp2 with
                           inl c3 =>
                              (* 3 *)
                              match c3 with Build_C la3 =>
                                 forall a3 : A, In a3 la3 ->
                                    match a3 with Build_A cp3 =>
                                       match cp3 with
                                          inl c4 => (* 4 *) ... |
                                          inr p3 => exists u : U, In u (f c1)
                                       end
                                    end
                              end |
                           inr p2 => exists u : U, In u (f c1)
                        end
                     end
                  end |
            inr p1 => exists u : U, In u (f c1)
         end
      end
end.
Regards,
Jeff.
