coq-club - Re: [Coq-Club] coercing equality proofs
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Leonardo de Moura <leonardo AT microsoft.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coercing equality proofs
  • Date: Tue, 28 Jan 2014 16:44:52 -0500
You can get [@eq Prop (inhabited x) (inhabited y)], which is [@eq Prop ||x|| ||y||].  But this still does not give you [@eq Prop x y] without axioms, because there's no theorem that [inhabited : Type -> Prop] is injective on Props.  With univalence, though, you could do it.
-Jason
On Tue, Jan 28, 2014 at 3:50 PM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
It should be possible to do using the "bracket type" projection Type -> Prop  but I am not sure how exactly it works in Coq since I do not use Prop.
V.
On Jan 28, 2014, at 2:30 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
There is no way without axioms.  Going the other way is straightforwad: "match (H : @eq Prop x y) in (_ = y') return (@eq Type x y') with eq_refl => eq_refl end".  It does not work going the other way because y' would be a Type, and you'd be trying to make it a Prop.  If you think about this homotopy-theoretically (google homotopy type theory), there is no guarantee that every point along a path @eq Type_i (x : Type_j) (y : Type_j) will be small enough to fit into a Type_j.  You could do it with Axiom K, I believe.
-Jason
On Jan 28, 2014 1:06 PM, "Leonardo de Moura" <leonardo AT microsoft.com> wrote:
Hi,
Given (x y : Prop), I’m wondering about how to coerce an equality proof for (@eq Type x y) to (@eq Prop x y).
Is this possible?
Thanks,
Leo
