- From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Recursive proposition with exists
- Date: Tue, 4 Feb 2014 17:16:16 +0000
- Accept-language: en-GB, en-US
Thanks, the trick works well in L2, but unfortunately not in my main proof. In fact, the error reported, i.e.
The term "FIX c prefix" has type
"exists t : Table, AttributeToColumn c t prefix"
while it is expected to have type
"exists t : Table,
AttributeToColumn (Build_Class oid super (Some c) attributes) t prefix".
is similar to the one I would have expected [exact (FIX c')] to produce in L2, because (FIX c') is of type exists t : T, AC c' t, not exists t : T, AC (Build_C (Some c')) t. Here's the current goal just before [exact (FIX c')] is invoked.
Regards,
Jeff.
FIX : forall c : C, exists t : T, AC c t
c' : C
______________________________________(1/1)
Any thoughts on what could be wrong?
Regards,
Jeff.
On 4 Feb 2014, at 16:07, Arnaud Spiwack wrote:
The trick is to refrain from choosing a witness too early:
Lemma L2 : forall c : C, exists t : T, AC c t.
Proof.
fix FIX 1.
intros [[ c' | ]].
+ exact (FIX c').
+ exists Build_T.
exact I.
Qed.
On 4 February 2014 16:55, Terrell, Jeffrey <jeffrey.terrell AT kcl.ac.uk> wrote:
Could someone help me to solve L2? I've tried ex_intro but I can't seem to get it to work. Many thanks.
Regards,
Jeff.
Inductive C : Set :=
Build_C : option C -> C.
Inductive T : Set :=
Build_T : T.
Fixpoint AC (c : C) (t : T) {struct c} : Prop :=
match c with
Build_C None => True |
Build_C (Some c') => AC c' t
end.
Lemma L1 : forall c : C, forall t : T, AC c t.
Proof.
fix FIX 1.
intros c t.
destruct c as [o].
destruct o as [c' |].
simpl.
exact (FIX c' t).
simpl.
trivial.
Qed.
Proof.
fix FIX 1.
intro c.
exists (Build_T).
destruct c as [o].
simpl.
admit.
simpl.
trivial.
Qed.
- [Coq-Club] Recursive proposition with exists, Terrell, Jeffrey, 02/04/2014
- Re: [Coq-Club] Recursive proposition with exists, Arnaud Spiwack, 02/04/2014
- Re: [Coq-Club] Recursive proposition with exists, Terrell, Jeffrey, 02/04/2014
- Re: [Coq-Club] Recursive proposition with exists, Terrell, Jeffrey, 02/05/2014
- Re: [Coq-Club] Recursive proposition with exists, Arnaud Spiwack, 02/05/2014
