coq-club - Re: [Coq-Club] Recursive proposition with exists
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Recursive proposition with exists
  • Date: Wed, 5 Feb 2014 07:19:15 +0100
Because [AC (Build_C (Some c')) t] reduces to [AC c' t], by definition.
Of course, usually, you may need the [t] returned by [FIX c'], then you can do something along the lines of
generalize (FIX c').
intros [t r].
exists (f t). (* for a good choice of [f] *)
exact r.
Or something.
On 5 February 2014 06:42, Terrell, Jeffrey <jeffrey.terrell AT kcl.ac.uk> wrote:
Dear Arnaud,
Just to clarify, why does [exact (FIX c')] prove the following goal? I know it does, but why?
FIX : forall c : C, exists t : T, AC c t
c' : C
______________________________________(1/1)
exists t : T, AC (Build_C (Some c')) t
Regards,
Jeff.
On 4 Feb 2014, at 17:16, Terrell, Jeffrey wrote:
Thanks, the trick works well in L2, but unfortunately not in my main proof. In fact, the error reported, i.e.
The term "FIX c prefix" has type
 "exists t : Table, AttributeToColumn c t prefix"
 while it is expected to have type
 "exists t : Table,
    AttributeToColumn (Build_Class oid super (Some c) attributes) t prefix".
is similar to the one I would have expected [exact (FIX c')] to produce in L2, because (FIX c') is of type exists t : T, AC c' t, not exists t : T, AC (Build_C (Some c')) t. Here's the current goal just before [exact (FIX c')] is invoked.
c' : C
Any thoughts on what could be wrong?
Regards,
Jeff.
On 4 Feb 2014, at 16:07, Arnaud Spiwack wrote:
The trick is to refrain from choosing a witness too early:
Lemma L2 : forall c : C, exists t : T, AC c t.
Proof.
   fix FIX 1.
   intros [[ c' | ]].
   + exact (FIX c').
   + exists Build_T.
     exact I.
Qed.
On 4 February 2014 16:55, Terrell, Jeffrey <jeffrey.terrell AT kcl.ac.uk> wrote:
Could someone help me to solve L2? I've tried ex_intro but I can't seem to get it to work. Many thanks.
Regards,
Jeff.
Inductive C : Set :=
   Build_C : option C -> C.
Inductive T : Set :=
   Build_T : T.
Fixpoint AC (c : C) (t : T) {struct c} : Prop :=
   match c with
      Build_C None => True |
      Build_C (Some c') => AC c' t
   end.
Lemma L1 : forall c : C, forall t : T, AC c t.
Proof.
   fix FIX 1.
   intros c t.
   destruct c as [o].
   destruct o as [c' |].
      simpl.
      exact (FIX c' t).
   simpl.
   trivial.
Qed.
Proof.
   fix FIX 1.
   intro c.
   exists (Build_T).
   destruct c as [o].
   simpl.
      admit.
   simpl.
   trivial.
Qed.
