coq-club - Re: [Coq-Club] impredicativity of Prop
  • From: Kristopher Micinski <krismicinski AT gmail.com>
  • To: coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] impredicativity of Prop
  • Date: Sat, 8 Feb 2014 12:46:52 -0500
In Coq the stratification constraints are implicit in Type and solved
under the hood in the Coq kernel.
So there's no such thing as Type_i, it only exists as a phantom inside
the internal solver, which enforces that there is a assignment of
levels that makes everything work out.
The difference between first and higher order logic is as simple as
being able to quantify over functions in Set, e.g.,
Coq < Print nat_ind.
nat_ind =
fun P : nat -> Prop => nat_rect P
: forall P : nat -> Prop,
P 0 -> (forall n : nat, P n -> P (S n)) -> forall n : nat, P n
Even a simple induction principle is higher order. It takes a
predicate on nats (`nat -> Prop`).
I actually haven't heard the term `quantor` before, but I think it's
the level that goes on a hierarchy of universes for constraints. Is
that correct?
I apologize if I'm wasting your time, I should probably go learn about
Agda's universes to answer this question more correctly..
Kris
On Sat, Feb 8, 2014 at 5:28 AM, Kirill Taran
<kirill.t256 AT gmail.com>
wrote:
> Kristopher,
> You are right about Set/Prop/Type model in Coq.
> Because in Agda universes are Set 0/Set 1/Set 2/etc., it seems that we can
> write all programs we can write in Coq, but I am not really sure about
> pitfalls.
> The question actually was about difference between 1-order and higher-order
> logic.
> Is only difference in presence of quantors on all predicates? If yes, we see
> that in 1-order logic we can express all the same things we can in
> higher-order with just specification of "level".
> (Like in Agda we do "forall l : level, forall P : Set l, ...".)
> Sincerely,
> Kirill Taran
> On Sat, Feb 8, 2014 at 6:08 AM, Kristopher Micinski
> wrote:
>> disclaimer: I don't know much about Agda
>> Prop is impredicative in Coq, while Set is predicative. Type is
>> actually a special collection of universes that is indexed by naturals
>> (in a way to make a "nested" set of universes) to enforce
>> stratification constraints. The basic idea is this:
>> Type_n
>> Type_{n-1}
>> Type_1
>> Set Prop
>> There's an elimination restriction for Prop so that you can't do bad
>> things that would lead to inconsistencies. The best description of
>> them is probably this (in my view, which is pragmatic in nature..)
>> http://adam.chlipala.net/cpdt/html/Universes.html
>> I don't know much about Agda, but I am almost certain that it does not
>> model only first order logic, otherwise why would people use it?
>> Predicativity vs., impredicativity is simply about whether you define
>> an object in reference to itself. This causes sticky paradoxes that
>> you have to be careful to avoid.
>> Kris
>> On Fri, Feb 7, 2014 at 9:27 AM, Kirill Taran
>> wrote:
>> > Hello,
>> > Why we need impredicativity of Prop?
>> > Also, is there difference in expressivity between Coq and Agda due
>> > difference in predicativity of Prop (in Agda everything is predicative)?
>> > Also, is it right assertion that "Coq models higher-order logic while
>> > Agda
>> > models first-order logic"? If yes, are first-order and higher-order
>> > logic
>> > essentialy "the same"?
>> > (My assumption about that is that *-order logics have a lot of sorts and
>> > logics modelled by type theories are in some sense "equal" due to
>> > essense of
>> > TT.)
>> > Sincerely,
>> > Kirill Taran
