- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] impredicativity of Prop
- Date: Sun, 09 Feb 2014 15:24:16 +0100
Am 07.02.2014 15:27, schrieb Kirill Taran:
Hello,
Why we need impredicativity of Prop?
Also, is there difference in expressivity between Coq and Agda due difference in predicativity of Prop (in Agda everything is predicative)?
Hi Kirill,
Impredicativity means, informally, that if you create a proposition that talks about all propositions, it also talks about itself.
In Coq this is implemented by the (informal...) typing rule
A : U x : A => B : Prop
forall x : A , B : Prop
In particular, if A = Prop (and U = Type_0), you get:
(forall x : Prop , B) : Prop
Thus, you could instantiate x with (forall x : Prop , B).
For types this doesn't work, as the term would automatically have type U (or higher). For the formal typing rules, refer to: http://coq.inria.fr/doc/Reference-Manual006.html#sec167
Kind regards, jonas
- [Coq-Club] impredicativity of Prop, Kirill Taran, 02/07/2014
- Re: [Coq-Club] impredicativity of Prop, Kristopher Micinski, 02/08/2014
- Re: [Coq-Club] impredicativity of Prop, Kirill Taran, 02/08/2014
- Re: [Coq-Club] impredicativity of Prop, Jonas Oberhauser, 02/09/2014
- Re: [Coq-Club] impredicativity of Prop, Ali Assaf, 02/12/2014
- Re: [Coq-Club] impredicativity of Prop, Matthieu Sozeau, 02/12/2014
- Re: [Coq-Club] impredicativity of Prop, Altenkirch Thorsten, 02/12/2014
- Re: [Coq-Club] impredicativity of Prop, Kirill Taran, 02/13/2014
- Re: [Coq-Club] impredicativity of Prop, Kristopher Micinski, 02/13/2014
