- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] totality and consistency
- Date: Wed, 12 Feb 2014 07:08:38 +0100
On 12 February 2014 00:57, Greg Morrisett <greg AT eecs.harvard.edu> wrote:
Yes. I'd argue that if termination checking is allowing for:
On Feb 11, 2014, at 6:54 PM, Mitchell Wand <wand AT ccs.neu.edu> wrote:
> Is this a CBN vs. CBV issue?
Fixpoint f (x:nat) : nat := let z := f(x) in 0
then the language isn't confluent,
Well, this is quite unlikely to compromise confluence (hell, deactivating termination checking altogether shouldn't compromise confluence). So I don't think this is a problem. But remember: it's really a bug. If the termination checking of Coq changes for something more flexible/robust like sized types, someday, this term will be rejected. And so, you should reject it as well (with the power of you miiiiiind!), and not be too bothered about it.
and so it's easy to run into
problems when reduction is done one way, and extraction + evaluation
is done another.
But I suspect Pierre was smart enough to cover the bases here
and it's not really a problem. I was just hoping someone knew
what, exactly, is going on.
Actually, extraction has a bunch of optimisations (mostly a bit of partial evaluation plus some commutative cuts, if I remember correctly). It's certainly not trivial that the extracted code does the same thing as the Coq code, but surely, this is still easier than understanding why you can erase proof of acc which are the structural argument of a fixed point.
- Re: [Coq-Club] totality and consistency, (continued)
- Re: [Coq-Club] totality and consistency, Arnaud Spiwack, 02/10/2014
- Re: [Coq-Club] totality and consistency, Kirill Taran, 02/10/2014
- Re: [Coq-Club] totality and consistency, Matthieu Sozeau, 02/10/2014
- Re: [Coq-Club] totality and consistency, Greg Morrisett, 02/10/2014
- Re: [Coq-Club] totality and consistency, Guillaume Melquiond, 02/10/2014
- Re: [Coq-Club] totality and consistency, Kirill Taran, 02/11/2014
- Re: [Coq-Club] totality and consistency, Greg Morrisett, 02/12/2014
- Re: [Coq-Club] totality and consistency, Mitchell Wand, 02/12/2014
- Re: [Coq-Club] totality and consistency, Arnaud Spiwack, 02/12/2014
- Re: [Coq-Club] totality and consistency, Matthieu Sozeau, 02/12/2014
- Re: [Coq-Club] totality and consistency, Bruno Barras, 02/12/2014
