- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] totality and consistency
- Date: Wed, 12 Feb 2014 10:47:21 +0100
Hi,
Let me make my point again: what you see is not what you get ([Print f])!
The definition of f that goes into the kernel does not contain the let
binding anymore, so SN is preserved, and all reduction strategies work.
Extraction will use the kernel term as well, not the pre-term wrote by
the user.
Cheers,
— Matthieu
On 12 févr. 2014, at 00:57, Greg Morrisett
<greg AT eecs.harvard.edu>
wrote:
> On Feb 11, 2014, at 6:54 PM, Mitchell Wand
> <wand AT ccs.neu.edu>
> wrote:
>> Is this a CBN vs. CBV issue?
> Yes. I'd argue that if termination checking is allowing for:
> Fixpoint f (x:nat) : nat := let z := f(x) in 0
> then the language isn't confluent, and so it's easy to run into
> problems when reduction is done one way, and extraction + evaluation
> is done another.
> But I suspect Pierre was smart enough to cover the bases here
> and it's not really a problem. I was just hoping someone knew
> what, exactly, is going on.
> -Greg
- Re: [Coq-Club] totality and consistency, (continued)
- Re: [Coq-Club] totality and consistency, Kirill Taran, 02/10/2014
- Re: [Coq-Club] totality and consistency, Matthieu Sozeau, 02/10/2014
- Re: [Coq-Club] totality and consistency, Arnaud Spiwack, 02/10/2014
- Re: [Coq-Club] totality and consistency, Greg Morrisett, 02/10/2014
- Re: [Coq-Club] totality and consistency, Guillaume Melquiond, 02/10/2014
- Re: [Coq-Club] totality and consistency, Kirill Taran, 02/11/2014
- Re: [Coq-Club] totality and consistency, Greg Morrisett, 02/12/2014
- Re: [Coq-Club] totality and consistency, Mitchell Wand, 02/12/2014
- Re: [Coq-Club] totality and consistency, Arnaud Spiwack, 02/12/2014
- Re: [Coq-Club] totality and consistency, Matthieu Sozeau, 02/12/2014
- Re: [Coq-Club] totality and consistency, Bruno Barras, 02/12/2014
