Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge
- To: Andreas Abel <abela AT chalmers.se>, coq-club AT inria.fr, Agda List <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge
- Date: Sun, 02 Mar 2014 14:50:59 -0500
Oh, thanks Andreas! I was curious to know if this paradox could be ported, but didn't know enough about co-induction in Agda.
It seems to indicate that this is more than just an implementation bug. Which is not surprising after all, it is the dual of the original problem with fixpoints on inductive types.
A minor point, I think you can get rid of CoFalse. I had introduced it in the original Coq example because of an implementation detail (bug?) of the guard checker, which by accident almost prevented the paradox, but not quite :)
prop = Set
data False : prop where
data Pandora : prop where
C : ∞ False → Pandora
postulate
ext : (False → Pandora) → (Pandora → False) → False ≡ Pandora
foo : False ≡ Pandora
foo = ext (λ{ () })
(λ{ (C c) → (♭ c)})
loop : False
loop rewrite foo = C (♯ loop)
Maxime.
On 03/02/2014 02:07 PM, Andreas Abel wrote:
Here is the Agda version of this paradox:
open import Common.Coinduction
open import Common.Equality
prop = Set
data CoFalse : prop where
CF : False → CoFalse
C : ∞ CoFalse → Pandora
postulate
ext : (CoFalse → Pandora) → (Pandora → CoFalse) → CoFalse ≡ Pandora
out : CoFalse → False
out (CF f) = f
foo : CoFalse ≡ Pandora
foo = ext (λ{ (CF ()) })
(λ{ (C c) → CF (out (♭ c))})
loop : CoFalse
false : False
false = out loop
This concerns the current "musical" coinduction mechanism (which was never sound anyway).
I could not reproduce it with copatterns, since with and rewrite are not implemented for copatterns and a use of subst destroys guardedness. (I will think twice how I implement it now... ;-)).
Cheers,
Andreas
On 27.02.2014 06:12, Jason Gross wrote:
I thought that your extra CoFalse argument to CF was redundant, so I
tried removing it. Then I got
Error:
Recursive definition of loop is ill-formed.
In environment
loop : CoFalse
Recursive call on a non-recursive argument of constructor
"loop".
Recursive definition is:
"match foo in (_ = T) return T with
| eq_refl => C loop
end".
What does this mean? Does Coq somehow think that "loop" is a
constructor? And why is whether or not "loop" is valid for a recursive
call dependent on whether or not there's a dummy CoFalse hypothesis of CF?
-Jason
On Wed, Feb 26, 2014 at 11:56 PM, Maxime Dénès
<mail AT maximedenes.fr
<mailto:mail AT maximedenes.fr>>
wrote:
Hello there,
As some of you may have been expecting, episode two is out. This
time featuring co-inductive types!
------------------------------__------------------------------__---------------------
CoInductive CoFalse : Prop := CF : CoFalse -> False -> CoFalse.
CoInductive Pandora : Prop := C : CoFalse -> Pandora.
Axiom prop_ext : forall P Q : Prop, (P<->Q) -> P = Q.
Lemma foo : Pandora = CoFalse.
apply prop_ext.
constructor.
intro x; destruct x; assumption.
exact C.
Qed.
CoFixpoint loop : CoFalse :=
match foo in (_ = T) return T with eq_refl => C loop end.
Definition ff : False := match loop with CF _ t => t end.
I am still not sure if this is an implementation bug of the guard
for cofixpoints or something more fundamental.
Below is a variation done with Arthur Azevedo de Amorim (requires
some of the definitions above):
Inductive omega := Omega : omega -> omega.
Lemma H : omega = CoFalse.
Proof.
apply prop_ext; constructor.
induction 1; assumption.
destruct 1; destruct H0.
Qed.
CoFixpoint loop' : CoFalse :=
match H in _ = T return T with
eq_refl =>
Omega match eq_sym H in _ = T return T with eq_refl => loop' end
end.
Definition ff' : False := match loop' with CF _ t => t end.
We'll work on a fix before the next Coq release.
Maxime.
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Andreas Abel, 03/02/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Maxime Dénès, 03/02/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Altenkirch Thorsten, 03/03/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Andreas Abel, 03/03/2014
