- To: <coq-club AT inria.fr>, Agda List <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] Propositional extensionality: the return of the revenge
- Date: Sun, 2 Mar 2014 20:07:10 +0100
Here is the Agda version of this paradox:
open import Common.Coinduction
open import Common.Equality
prop = Set
data False : prop where
data CoFalse : prop where
CF : False → CoFalse
data Pandora : prop where
C : ∞ CoFalse → Pandora
postulate
ext : (CoFalse → Pandora) → (Pandora → CoFalse) → CoFalse ≡ Pandora
out : CoFalse → False
out (CF f) = f
foo : CoFalse ≡ Pandora
foo = ext (λ{ (CF ()) })
(λ{ (C c) → CF (out (♭ c))})
loop : CoFalse
loop rewrite foo = C (♯ loop)
false : False
false = out loop
This concerns the current "musical" coinduction mechanism (which was never sound anyway).
I could not reproduce it with copatterns, since with and rewrite are not implemented for copatterns and a use of subst destroys guardedness. (I will think twice how I implement it now... ;-)).
Cheers,
Andreas
On 27.02.2014 06:12, Jason Gross wrote:
I thought that your extra CoFalse argument to CF was redundant, so I
tried removing it. Then I got
Error:
Recursive definition of loop is ill-formed.
In environment
loop : CoFalse
Recursive call on a non-recursive argument of constructor
"loop".
Recursive definition is:
"match foo in (_ = T) return T with
| eq_refl => C loop
end".
What does this mean? Does Coq somehow think that "loop" is a
constructor? And why is whether or not "loop" is valid for a recursive
call dependent on whether or not there's a dummy CoFalse hypothesis of CF?
-Jason
On Wed, Feb 26, 2014 at 11:56 PM, Maxime Dénès
<mail AT maximedenes.fr
<mailto:mail AT maximedenes.fr>>
wrote:
Hello there,
As some of you may have been expecting, episode two is out. This
time featuring co-inductive types!
------------------------------__------------------------------__---------------------
CoInductive CoFalse : Prop := CF : CoFalse -> False -> CoFalse.
CoInductive Pandora : Prop := C : CoFalse -> Pandora.
Axiom prop_ext : forall P Q : Prop, (P<->Q) -> P = Q.
Lemma foo : Pandora = CoFalse.
apply prop_ext.
constructor.
intro x; destruct x; assumption.
exact C.
Qed.
CoFixpoint loop : CoFalse :=
match foo in (_ = T) return T with eq_refl => C loop end.
Definition ff : False := match loop with CF _ t => t end.
I am still not sure if this is an implementation bug of the guard
for cofixpoints or something more fundamental.
Below is a variation done with Arthur Azevedo de Amorim (requires
some of the definitions above):
Inductive omega := Omega : omega -> omega.
Lemma H : omega = CoFalse.
Proof.
apply prop_ext; constructor.
induction 1; assumption.
destruct 1; destruct H0.
Qed.
CoFixpoint loop' : CoFalse :=
match H in _ = T return T with
eq_refl =>
Omega match eq_sym H in _ = T return T with eq_refl => loop' end
end.
Definition ff' : False := match loop' with CF _ t => t end.
We'll work on a fix before the next Coq release.
Maxime.
Andreas Abel <>< Du bist der geliebte Mensch.
Depeartment of Computer Science and Engineering
Chalmers and Gothenburg University, Sweden
andreas.abel AT gu.se
http://www2.tcs.ifi.lmu.de/~abel/
- Re: [Coq-Club] Propositional extensionality: the return of the revenge, Andreas Abel, 03/02/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Maxime Dénès, 03/02/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Altenkirch Thorsten, 03/03/2014
- Re: [Coq-Club] [Agda] Re: Propositional extensionality: the return of the revenge, Andreas Abel, 03/03/2014
