- From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Small error-reporting bug and typeclass question
- Date: Wed, 5 Mar 2014 14:16:35 -0500
I'm trying to write a simple example in which I use a monoid typeclass instance, namely { list [A], (app A), (nil A) } as a parameter to a reduce/foldr function. I'm having a little trouble getting overloading to resolve the type of list element (in the example here, it's string). Any help would be appreciated.
Separately, I'd note that the error message produced for the last line of this short code segment is this: Error: The term "append_nil" has type "Monoid" while it is expected to have type "Monoid". This doesn't seem quite right.
Thanks!
Kevin
(* A [Monoid] typeclass on carrier [A] *)
Class Monoid {A: Type} : Type :=
dot : A -> A -> A;
dot_assoc: forall x y z : A, dot x (dot y z) = dot (dot x y) z;
id_left: forall x, dot id x = x;
id_right: forall x, dot x id = x
(** Instance for [list A] with [app] and [nil] *)
Instance append_nil {A: Type}: Monoid :=
{ dot := @app A; id := nil }.
Proof.
Require Import List.
intros x y z.
generalize dependent A.
exact List.app_assoc.
exact List.app_nil_l.
exact List.app_nil_r.
Defined.
(** * A "safe" foldr function using a Monoid *)
Fixpoint sfoldr {A: Type} (l: list A) (m: Monoid): A :=
match l with
| nil => id
| cons h t => dot h (sfoldr t m)
end.
Require Import String.
Open Scope string_scope.
Compute sfoldr (cons "Hello " (cons "World!" nil)) append_nil.
- [Coq-Club] Small error-reporting bug and typeclass question, Kevin Sullivan, 03/05/2014
- Re: [Coq-Club] Small error-reporting bug and typeclass question, Adam Chlipala, 03/05/2014
- Re: [Coq-Club] Small error-reporting bug and typeclass question, Kevin Sullivan, 03/05/2014
