- From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Small error-reporting bug and typeclass question
- Date: Wed, 5 Mar 2014 14:42:21 -0500
Of course. Thanks. --Kevin
On Wed, Mar 5, 2014 at 2:23 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 03/05/2014 02:16 PM, Kevin Sullivan wrote:The message sounds right to me, considering normal Coq conventions, because the parameter to [Monoid] is marked as implicit. Try the usual fix of running [Set Printing All], or another command to trigger a less verbose printing mode that still includes what you need.
Separately, I'd note that the error message produced for the last line of this short code segment is this: Error: The term "append_nil" has type "Monoid" while it is expected to have type "Monoid". This doesn't seem quite right.
- [Coq-Club] Small error-reporting bug and typeclass question, Kevin Sullivan, 03/05/2014
- Re: [Coq-Club] Small error-reporting bug and typeclass question, Adam Chlipala, 03/05/2014
- Re: [Coq-Club] Small error-reporting bug and typeclass question, Kevin Sullivan, 03/05/2014
