- From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] integrating extracted code into industrial frameworks
- Date: Thu, 6 Mar 2014 07:54:40 -0500
FWIW, This paper -- describing a case study using extraction to produce a drop-in replacement for a Haskell window manager -- which I found based on a few of the comments I got in response to my query, provides a pretty nice overview of the issues that arise when trying to integrate extracted code into a legacy environment.
My favorite qotation: If you want to do formal verification, sed should not be a mandatory part of your toolchain.
Kevin
On Thu, Mar 6, 2014 at 7:38 AM, Kevin Sullivan <sullivan.kevinj AT gmail.com> wrote:
:-) I appreciate the response (really). I'll go do that. --KevinOn Thu, Mar 6, 2014 at 7:23 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
My response here is in danger of coming across as rudely close to "RTFM," but: have you read the whole chapter of the Coq reference manual called "Extraction of programs in Objective Caml and Haskell"? There I think you find all the commands you need to do extraction to alternative type representations, as long as your original code contains no explicit pattern matches on those types.
On 03/06/2014 07:14 AM, Kevin Sullivan wrote:Thanks Greg and Cedric,
I'm not necessarily committed to Haskell. What hooks did you, Greg, have in mind for doing such mappings/replacements when extracting to OCaml?
Kevin
On Wed, Mar 5, 2014 at 11:05 PM, Greg Morrisett <greg AT eecs.harvard.edu> wrote:
I don't have experience extracting Haskell, but when I do OCaml,
I tend to map certain things (ascii, nat) to native OCaml
types (e.g., char, bignum). I agree it's less than optimal, but
that's the price of interoperability with legacy code...
Anyway, there are good hooks for doing this kind of replacement.
- [Coq-Club] integrating extracted code into industrial frameworks, Kevin Sullivan, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Greg Morrisett, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Kevin Sullivan, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Robbert Krebbers, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Adam Chlipala, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Cedric Auger, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Xavier Leroy, 03/06/2014
- Re: [Coq-Club] integrating extracted code into industrial frameworks, Kevin Sullivan, 03/07/2014
