coq-club - Re: [Coq-Club] integrating extracted code into industrial frameworks
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] integrating extracted code into industrial frameworks
  • Date: Thu, 06 Mar 2014 19:03:43 +0100
On 06/03/14 01:49, Kevin Sullivan wrote:
> The question is, what's the current best practice for "bridging" from Coq's
> types to analogs provided and used natively in target languages and related
> frameworks?
For what it's worth, here is what I do for CompCert, using extraction
to OCaml.
1- Before extraction, use
Require Import ExtrOcamlBasic.
Require Import ExtrOcamlString.
This maps Coq's booleans, lists, pairs, and characters to OCaml's.
Already a good start.
2- For (exact) integers and strings, I prefer to keep Coq's definitions
unchanged and convert to/from OCaml's integers and strings as needed.
You can find the conversion functions I use in the lib/Camlcoq.ml file
of the CompCert distribution (http://compcert.inria.fr/).
3- The more I write OCaml code that must interface with Coq-extracted
code, the more I tend to use Coq's datatypes in the OCaml code. For
example, Coq's "Z" type is a half-decent implementation of big
integers: not as fast as OCaml's bignums (or alternatives like
Zarith), but not prohibitively slow either, and provably correct!
Hope this helps,
- Xavier Leroy
