- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] XML and Coq
- Date: Thu, 06 Mar 2014 15:21:35 +0100
Dear Coq-Club,
First, I have two problems to report:
- When I try to use the command "Show XML Proof.", I always
get the message:
"Anomaly: Xmlcommand.show_pftreestate is not supported in this version..
Please report."
This problem occurs whether or not I set the COQ_XML_LIBRARY_ROOT
variable.
- When I use the command "coqc -xml test.v"(or coqtop -xml test.v) and the
is set I get this message:
"Uncaught exception: End_of_file
Anomaly: Error executing "/pathtocoqinstall/bin/coqdoc --html -s
--body-only --no-index --latin1 --raw-comments -o
/pathinCOQ_XML_LIBRARY_ROOT/test.theory.xml
/pathinCOQ_XML_LIBRARY_ROOT/test.theory.v".
Please report."
I joined an exemple where those errors occur. I tried with the version
8.4pl3 and
with a fresh clone of coq's git. Both version are compiled for Linux.
Also, I was wondering, is there a way to recover the vernac files from the
exported XML files?
Best regards,
Julien Thierry
Require Import Zorder.
Require Import BinInt.
Theorem testing : (0 <= 1)%Z.
Proof.
apply Zle_0_1.
Qed.
- [Coq-Club] XML and Coq, Julien Thierry, 03/06/2014
