- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Facing troubles with Makefiles
- Date: Thu, 06 Mar 2014 16:20:53 +0100
Le jeudi 06 mars 2014 à 14:44 +0100, Julien Thierry a écrit :
> Is there a way to tell coq_makefile to map physical paths to logical paths
> without
> loosing my libraries when using make clean?
No, and that a serious problem !!!
Well OK don't put
> -R /pathtowhy3install/lib/why3/coq Why3
in your Make file and then use
> make COQLIBS="-R /pathtowhy3install/lib/why3/coq Why3 -R . Mystuff -R
foo other__stuff_from_the_Makefile" all
and you might go somewhere but it is a pity ...
It would have been much easier if the Why3 lib could install itself in a
directory called Why3 that is 'included' by coq ... For example, by
doing
> mkdir /pathtowhy3install/lib/why3/coq/Why3 &&
mv /pathtowhy3install/lib/why3/coq/*.vo /pathtowhy3install/lib/why3/coq/Why3/
> export XDG_DATA_DIRS=$XDG_DATA_DIRS:/pathtowhy3install/lib/why3/
coq{top,dep,c} would be able to Require Why3.* ...
I didn't find yet any good idea for a
-R_for_coqtop_and_coqdep_but_not_coq_makefile option in coq_makefile.
Nevertheless, this question is postponed to "after the revolution about
what physical paths Coq includes by default". Revolution that is stuck
somehow somewhere (in its consequences about native_compute if I
understood well) and have to be brought back to life !
All the best,
Pierre B.
> Regards,
- [Coq-Club] Facing troubles with Makefiles, Julien Thierry, 03/06/2014
- Re: [Coq-Club] Facing troubles with Makefiles, Pierre Boutillier, 03/06/2014
- Re: [Coq-Club] Facing troubles with Makefiles, Julien Thierry, 03/06/2014
